Brr, it,s cold #786258 02/04/07 04:45 AM
O
oldgreen Offline OP
50 below this morning with the windchill and 37 below tonight with a windchill of 47 below. But the old CJ with the mods I made has great heat even at these temps but it does need to be plugged in to start.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: Brr, it,s cold [Re: oldgreen] #786259 02/04/07 06:08 AM
F
Fred Blackstone Offline
Old Green, hey? I recently found myself living in near-Canadian-like weather conditions, minus 30 degrees F. Three year old battery must have been frozen, won't turn the starter! So, you apparently have a block heater? In your opinion, for -30 degrees F. temperatures, which would be the best application, a block heater or a battery heater?
My experience, limited, of course, has been that if the Jeep engine starts, it will eventually warm the engine coolant and engine oil. Fortunately, I had a 750 CCA Orbital battery to replace the original 600 CCA Jeep battery, and got to work although the Jeep was mighty cold even though I warmed the engine for about 10 minutes before heading out.
Re: Brr, it,s cold [Re: Fred Blackstone] #786260 02/04/07 04:44 PM
O
oldgreen Offline OP
Definitly the block heater, without it your dead in the water. Plus I have a spare yellow top optima behind the pass seat that is used for the winch and the stereo that I can run booster cables off of. Don,t do much wheeling in these temps though, it,s a little dangerous if you have a breakdown.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5935 MB (Peak: 0.6467 MB) Data Comp: Off Server Time: 2026-06-21 00:07:22 UTC
