Page 1 of 3 1 2 3
1st Gen Shifting into 4th gear problems #786282 02/04/07 06:07 AM
2M4Dale Offline OP
I have an 85 Monty SWB with the 4 cylinder and 5 speed tranny. I'm having some trouble with shifting into fourth gear. <img src="/forums/images/graemlins/frown.gif" alt="" />
I cannot just position the shifter into the 4th, let off the clutch, give gas and go. I must hold the shifter into the gate, let off the clutch and load the drive train by gassing it before I can release the shifter .... otherwise it pops out of gear. Once it's in forth and rolling ... no problems. It's just that there's no casual shifting into 4th anymore. It takes a bit of trickery. Oh yeah, I cannot downshift into forth at all .... won't stay in gear.
There are no other dissernable problems with the tranny or clutch .... so what's up ???
Thanks guys !
1987 Pontiac Fiero Coupe
1985 Mitsubishi Montero SWB 4cyl 5spd
1986 Mitsubishi Montero SWB 4cyl 5spd
1966 Pontiac Bonneville 4 door hardtop
Re: 1st Gen Shifting into 4th gear problems [Re: 2M4Dale] #786283 02/04/07 07:07 AM
Do you have problems in other gears? Have you pulled the shifter lever to check the plastic ball-thingy on the end inside the transmission tower?
Re: 1st Gen Shifting into 4th gear problems [Re: rxinhed] #786284 02/04/07 07:18 AM
52degrees Offline
Sounds like a synchro. Do 2nd while your in there. <img src="/forums/images/graemlins/frown.gif" alt="" />
KG6VNX
Re: 1st Gen Shifting into 4th gear problems [Re: rxinhed] #786285 02/04/07 07:24 AM
2M4Dale Offline OP
No problems with any other gears and ... Nope, I havn't pulled the shifter and checked The plastic ball thingy .... hoping it's not synchros .... Oh well ... I'll baby it till spring ... was planning on replacing the clutch soon anyways !!!
Re: 1st Gen Shifting into 4th gear problems [Re: 2M4Dale] #786286 02/04/07 05:41 PM
lordtrunks Offline
drop the 5 spd pile o' junk get your self an auto and put that bad boy in there no probs thats what i did love it.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 1st Gen Shifting into 4th gear problems [Re: 2M4Dale] #786287 02/04/07 08:22 PM
Kevin C Offline
Check the input shaft end play and the main shaft end play as well as the shifter system.
The third-fouth gear synchro hub bridges the gap between the input shaft and the main shaft so if there is a change in spacing from a failing bearing retainer of a bad bearing it will affect one or the other and sometimes both.
Kevin
Re: 1st Gen Shifting into 4th gear problems [Re: Kevin C] #786288 02/05/07 04:52 AM
your tranny is probably gonna be a nightmare from now on oh and if any of you diehard fivespeed guys are interested in making your tranny stronger i have something for you but keep in mind it'll only work on a good tranny and not a beat one or rebuilt one because once they get to a certain point they're gone no use in rebuilding because it will keep failing, now if it had been rebuilt just for preventive maintinace you're probably in good shape PM me for more details oh and this is a low dollar upgrade <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1st Gen Shifting into 4th gear problems [Re: TOASTY] #786289 02/05/07 07:49 PM
Ok, in each gear, going down the road at about 2500-3000rpms, let off the gas and reapply the gas while watching the movement of the shifter. Normal movement is only a slight rocking from side to side. If the shafts are moving front to back per KevinC, you should see the shifter bumping fore and aft.
In my experience with the KM145, the next step for yours is a loud shriek and a loss of either all gears, or all but 4th and revenge. With no more warning. I told you so x 3...
Re: 1st Gen Shifting into 4th gear problems [Re: fasteddy] #786290 02/06/07 03:28 AM
stony-man Offline
That's EXACTLY how it went down on my GENII 5 speed as well. I ended up find a low mileage tranny out of a salvage vehicle and having that put in. Like butta since.
Re: 1st Gen Shifting into 4th gear problems [Re: stony-man] #786291 02/06/07 12:40 PM
2M4Dale Offline OP
Sounds like I'm gonna need a tranny soon ... Oh Well, I'm gonna baby this thing as much as possible till spring and some warmer weather !!!
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6473 MB (Peak: 0.7688 MB) Data Comp: Off Server Time: 2026-06-07 11:34:25 UTC
