Wheel center caps #786391 02/04/07 03:21 PM
Airtight Offline OP
I have 99 TOD Trooper, and I was wondering why my front center caps on my wheels are so much longer than the back. The obvious answer would be that the hubs stick out in the front, but I see other troopers that appear to be my same year model (98-99) with 4 equal caps, the short ones. Does a TOD hub stick out like a locking/autolocking hub? Thanks.
Re: Wheel center caps [Re: Airtight] #786392 02/04/07 04:38 PM
litnin Offline
Not all 2nd generation Troopers were four wheel drive.
Ones without four wheel drive don't need the longer caps
in front to cover the hubs.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Wheel center caps [Re: litnin] #786393 02/04/07 05:14 PM
Airtight Offline OP
I'm sorry, I meant to put in my post that I've seen them with the TOD sticker on the back window, and all short caps. Unless someone is just faking with a sticker.
Re: Wheel center caps [Re: Airtight] #786394 02/09/07 11:00 AM
NATO308 Offline
As long as you do not have locking hubs, auto or manual, just have the plate that bolts up in place of the hubs for shift on the fly and track on demand, you should be able to put short caps on the front.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5981 MB (Peak: 0.6534 MB) Data Comp: Off Server Time: 2026-07-10 00:11:06 UTC
