2.6l Engine coolant temp sensor location ?????? #786477 02/04/07 07:07 PM
G
Goose Offline OP
Looking for the sensor on a 2.6l i want to disconect it so the engine will run on open loop.
Where is it and what does it look like????? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 2.6l Engine coolant temp sensor location ?????? [Re: Goose] #786478 02/05/07 12:56 PM
Bansil Offline
it's on passengerside of the intake,it has 1/4" spade connector and is about 1/2" long and about 12mm nut.
This on the amigo 2.6
hope this helps.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: 2.6l Engine coolant temp sensor location ?????? [Re: Goose] #786479 02/05/07 01:55 PM
hellbound Offline
This mite be a silly question but why on earth would you want to do that??
Adam.
Re: 2.6l Engine coolant temp sensor location ?????? [Re: hellbound] #786480 02/07/07 06:01 AM
G
Goose Offline OP
Well, my truck has a missfire due to low compression, now
here is the deal when it is cold and i start the truck it runs ok till the coolant temp sensor kicks in. Now what that does (if you dont know) is it keeps it running rich, the idea is the ecm thinks the engine is cold and feeds more fuel,
This is just so i can get around till i can fix the miss fire.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6034 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-05-29 18:59:27 UTC
