How to remove lower ball joint!!!!!!! #786511 02/04/07 10:00 PM
throwin_roost Offline OP
I am trying to replace my ball joints on a 93 rodeo and can't figure out how to get the lower one off of the steering knuckle. I have it loose but it wont pull out becuase the back of the wheel where the cv boot slips over will not allow it to. I dont want to have to take the entire wheel assembly off to do this. Any help would be much appreciated.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
Re: How to remove lower ball joint!!!!!!! [Re: throwin_roost] #786512 02/04/07 10:21 PM
strawmyers Offline
Isuzu Moderator
1. Remove hub face
2. Remove snap ring on end of axle shaft inside of hub
3. pull axle away from hub assembly/toward diff
That should give you enough clearance. If not, go ahead and unhook the tie rod and upper ball joint as well and the entire knuckle/hub assembly will come off in one piece. Watch your toes!
[edit] You'll want to take off the brake caliper as well if you have to pull the whole thing.
Sean Strawmyer
Re: How to remove lower ball joint!!!!!!! [Re: strawmyers] #786513 02/05/07 12:32 PM
Thanks a lot, you saved me. Awesome.
Re: How to remove lower ball joint!!!!!!! [Re: throwin_roost] #786514 02/07/07 06:09 AM
94rodeo Offline
Easiest way I removed mine last was with a torch <img src="/forums/images/graemlins/evil.gif" alt="" />
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: How to remove lower ball joint!!!!!!! [Re: 94rodeo] #786515 02/08/07 07:45 PM
V
VOLTRON Offline
when I replaced mine they were a mother to get out of the control arm so just take a hammer to the side of it and it will fall right out.
NOT ALL WHO WANDER ARE LOST
Re: How to remove lower ball joint!!!!!!! [Re: VOLTRON] #786516 02/09/07 01:29 PM
Thanks for all your help guys. Pulling the axle out of the hub a bit did the trick.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6083 MB (Peak: 0.6779 MB) Data Comp: Off Server Time: 2026-10-22 07:38:09 UTC
