Bent rear axle? #786731 02/05/07 11:28 PM
throwin_roost Offline OP
My 93 rodeo has been shaking badly and riding rough as hell lately and I havnt been able to figure it out. I changed shocks, wheel bearings, upper and lower ball joints, front sway bar bushings and it was still shaking like crazy going down the road. So today I put jack stands under the rear end and let the wheels spin in the air and noticed the wheels were not spinning straight and had a slight wobble to them. I sat in the truck and got it up to highway speed and I could definately feel and see the wheels were out of shape. Could this just be the tires or wheels out of round, or do I have a bigger problem? Any help would be great.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
Re: Bent rear axle? [Re: throwin_roost] #786732 02/06/07 12:30 PM
Thanks for the input.
Re: Bent rear axle? [Re: throwin_roost] #786733 02/06/07 03:47 PM
mlclark Offline
Isuzu Moderator
Glad we can help. We love it when people are grateful of the the FREE advice they receive around here. Especially since that advice you get is from individuals who are nice enough to spend their free time helping people they don't know, or have never met.
In the future, I suggest you wait a bit more than 12 hours for an answer or if you need one sooner, take it to a mechanic an PAY them to diagnose your problem.
Good Luck,
Michael
Re: Bent rear axle? [Re: throwin_roost] #786734 02/06/07 04:36 PM
BigSwede Offline
FWIW I am just seeing this post for the first time, didn't get on line last night <img src="/forums/images/graemlins/drunk.gif" alt="" />
Make sure the wheel studs are not stripped, that is a fairly common problem when shops use impact wrenches to put on lug nuts.
A tire can be out of round, sometimes a belt can break or separate and the tire will get the equivelant of a hernia, but usually not both tires at the same time.
What kind of wheels do you have? Steel wheels can get bent, but a cast aluminum wheel will usually crack before it bends that much.
If the whole axle was bent you wouldn't get a wheel wobble, the wheels just wouldn't track straight with each other...might get a shimmy of some kind though.
Serenity now!
Re: Bent rear axle? [Re: BigSwede] #786735 02/06/07 05:00 PM
RobG Offline
Just to echo what Steve said, i doubt its a bent axle, you've got something else going. And besides, those axles are pretty stout, you'd know it if you did something to tweak it.
-Rob
Re: Bent rear axle? [Re: mlclark] #786736 02/06/07 10:17 PM
Good Luck,
Michael
Sorry if I was impatient. I am very grateful and think this is a good forum and I get a lot out of it. I have stock aluminum wheels and the tires have high and low spots around the outer edge of the tires. Im gonna put a new set on and see how it goes. Thanks for the help.
Re: Bent rear axle? [Re: throwin_roost] #786737 02/07/07 06:05 AM
94rodeo Offline
I always love Michaels posts. He really is a nice guy. He is proboably just a little on edge while in school. I would also check your driveshaft for being balanced. I knocked a weight (tore off on a rock) loose while wheeling and it had a nasty shimmy until I got it rebalanced. I now have a slight shimmy from a bent rim.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: Bent rear axle? [Re: 94rodeo] #786738 02/07/07 06:02 PM
lttlbddy Offline
High and low spots are usually due to bad shocks. I see that you already changed your shocks but the damage could already be done. I am surprised that tire wear would turn into a bad vibration while driving.
I agree with the others that the bend axle housing sounds unlikely.
Getting it in for an tire balance and alignment might show you the problem.
Re: Bent rear axle? [Re: lttlbddy] #786739 02/09/07 03:48 PM
CPOM Offline
My amigo had a bent rear axle. The left rear tire had a noticible wobble to it. Funny thing is you didn't feel it at all. It had been in an accident before I bought it and hit on the left rear quarter. I changed it out and you couldn't tell the old axle was bent even by looking down at it.
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6280 MB (Peak: 0.7332 MB) Data Comp: Off Server Time: 2026-10-22 02:13:50 UTC
