anyone know someone in bc that does certifed propane converstaions
#786853
02/06/07 04:28 AM
do you know if they do it on fuel injected engines.. or old chevy 350's
Re: anyone know someone in bc that does certifed propane converstaions
[Re: d_a_r_kstar]
#786854
02/06/07 05:25 AM
the propane guy is from surrey or somewhere around there. you can do any engine you just have to change the intake. Propane is Injected since it is always under pressure. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: blackscout]
#786855
02/10/07 04:22 PM
I once looked into doing exactly that on a 350. It takes very special, hard to find injectors. There are problems with speed of vaporization. Do a search under "car and driver" (magazine) and "propane". They had an article on conversions on Crown Vic's that were f.i. There's an issue with vapor purge on first startup. The C.V. conv. used the dome light switch to trigger the purge cycle.
I like propane for the 130 octane and very clean burn. I've torn down traditional "mixer" propane conversion engines at 250k miles, and the combustion chambers and piston tops and ring lands were as clean as a motor with a blown head gasket - in other words, shiny clean like new castings.
Mixer is just a propane carb. Works fine, but not technically elegant, and not what I wanted for a turbo 350 in the old FJ55...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5945 MB (Peak: 0.6472 MB) Data Comp: Off Server Time: 2026-05-29 23:53:51 UTCValid HTML 5 and Valid CSS
