Tundra folks: What's your oil pressure reading? #786982 02/06/07 05:20 PM
Rockfish Offline OP
I have a new-to-me '05 Tundra with the V8. ~22K miles and an apparently-fresh oil change. My oil pressure gauge never gets above the half-way point (needle flat horizontal), even doing 70 mph up a mountain or 90 on the interstate. It is often down around the 1/4 mark if idling or easy driving.
The manual seems to say this is within the operating range, but it seems like it is down at the lower end of the OK range. It never gets above the half-way mark.
Is this what other folks are seeing?
TIA
Re: Tundra folks: What's your oil pressure reading? [Re: Rockfish] #786983 02/06/07 05:42 PM
Jake97T Offline
The 3.4L seems to operate under the same conditions as well, during idle it shows hardly any pressure at all, anything above that its never higher than half way...
Re: Tundra folks: What's your oil pressure reading? [Re: Jake97T] #786984 02/06/07 10:33 PM
ErikB Offline
Toyota Moderator
Its just a Toyota thing. You'd think they'd set up the guage so that that the normal readings were a little more confidence-inspiring...
Anyone I've ever heard of who actually measured the oil pressure found that it was in spec when the Toy guage read that way.
http://home.4x4wire.com/erik
Re: Tundra folks: What's your oil pressure reading? [Re: ErikB] #786985 02/06/07 10:39 PM
surlynkid Offline
i have a real gauge on my dash for the 4runner. i can translate 22RE to real psi, but not for a 5VZ.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Tundra folks: What's your oil pressure reading? [Re: surlynkid] #786986 02/07/07 12:49 AM
CJMT100 Offline
Mine is the same, at first whenits cold its really high on the T, whenit warms up it drops a bit.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-06-23 00:50:32 UTC
