suspension lift help me!!!!! #787274 02/07/07 10:08 AM
jonny_fookou Offline OP
need some help cause im gonna do a 3.4 swap in my 92 runner that requires 2in lift but otherwise 2 and 4in lift is just not enough i dont really no how the suspension works or what to do i would like to have atleast 10in of lift how would i go about doin this <img src="/forums/images/graemlins/confused.gif" alt="" />
really forget 10 im thinkin 2ft <img src="/forums/images/graemlins/nana.gif" alt="" />
--jonathan
Re: suspension lift [Re: jonny_fookou] #787275 02/07/07 10:32 AM
Snowtoy Offline
10" of lift on an IFS rig is impossible to get, the most you are going to get is 7-8" which is way more than is needed. Also to be safe that much lift would require widening the track width of your truck by 12 inches, which isn't possible unless you run full size axles.
A 2" bodylift is what you need for the 3.4 or modifying the hood. A suspension lift wont work since it doesn't do anything to increse room for the 3.4.
You should start with deciding what size tire you want to run, and lift the rig as little as possible to clear that size tire withminimal rubbing. With the 2" BL for the 3.4 and a 4inch suspension lift you should be able to clear 35's. With only the 2" BL , 1.5" ball joint spacers, and 2" rear spring lift, you should be able to clear 33's. Running tires bigger than 35's is going to require an SAS(straight axle swap) or a lot of cutting.
Re: suspension lift [Re: Snowtoy] #787276 02/07/07 10:37 AM
just kiddin about the 2ft thing but it would be bad as hell abut anyway u said 7 ur 8 that sounds kool but i cant find that anywhere the most ive found is 4in for a 92 runner do u no where like a specific site i could find that at
--jonathan
Re: suspension lift help me!!!!! [Re: jonny_fookou] #787277 02/07/07 04:01 PM
Skank Offline
sas it w/5 inch springs(trail gear or marlin are a couple choices), you'll be able to fit 40's, and be able to wheel with 36's....if you plan to actually wheel it, the ifs will be a weak point
Re: suspension lift help me!!!!! [Re: Skank] #787278 02/07/07 06:09 PM
4Crawler Offline
As noted, a body lift is what you need to make the engine swap easier:
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ2
Re: suspension lift [Re: jonny_fookou] #787279 02/07/07 11:35 PM
Snowtoy Offline
The 7-8" of lift would be a combo of lifts. It would take a 4" susp. lift, with a 3" body lift, a 1.5" ball joint lift, if needed you could then crank the torsion bars another 2" to achieve the 10" of lift. You would then have a truck that rode like hell and handled even worse.
What size tiore are you planning on running? Are you going to actually use this truck on the trail, or just araound town? These are questions that need to be answered, since a truck as tall as you are suggesting has no purpose being on any trail, it is unsafe.
Re: suspension lift [Re: Snowtoy] #787280 02/08/07 05:04 AM
how would i do a 1.5" ball joint lift?
--jonathan
Re: suspension lift [Re: jonny_fookou] #787281 02/08/07 05:22 AM
drainsbe Offline
Dave
86 4Runner, 22R-EB
Re: suspension lift [Re: drainsbe] #787282 02/08/07 04:33 PM
TexJeff87 Offline
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Hope you have deep pockets and good insurance. I assume you want it to still be street legal? Better check your lift laws.
If Mad Max had a 4runner...
Re: suspension lift [Re: TexJeff87] #787283 02/08/07 05:29 PM
http://4wheelonline.com/Products.aspx?CategoryId=20899&ProductId=66619
thats a pic of a 92 runner the way i want mine how much lift yall think it has on it cause i have no clue
--jonathan
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6377 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-10-21 17:31:08 UTC
