Stroking a 4.0L? Here is some real help...
#787398
02/07/07 09:25 PM
I have a 05' Rubicon Unlimited with a 4.0L <img src="/forums/images/graemlins/sleeping.gif" alt="" /> that just lacks what is needed with the 39.5 Irok's, 8" lift, winch, rock bumpers, rock rails and the weight goes on and on... I am about to do this build and thought of sharing this info with you. <img src="/forums/images/graemlins/cheers.gif" alt="" /> http://www.rockcrawler.com/techreports/stroker40/index.asp
Re: Stroking a 4.0L? Here is some real help...
[Re: Rubicon_Rob]
#787399
02/07/07 10:19 PM
LEAVE that wonderful engine alone and put the proper gears in there! What power you do get will be absorbed by the bad gear ratio you have now.. All those engines need is gearing properly! Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#787400
02/07/07 11:18 PM
LEAVE that wonderful engine alone and put the proper gears in there! What power you do get will be absorbed by the bad gear ratio you have now.. All those engines need is gearing properly! Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" /> I have 4:88's going to 5:13's before the engine job next week.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5939 MB (Peak: 0.6470 MB) Data Comp: Off Server Time: 2026-05-29 15:00:48 UTCValid HTML 5 and Valid CSS
