Page 1 of 4 1 2 3 4
I am running 37s now #787435 02/08/07 01:23 AM
cap510 Offline OP
Just wanted to let you guys now that I've installed new tires on my rig, I'm now running on 37s, they are MTRs mounted on 15x10 Black rockcrawler wheels. I've always wanted to test the limits of our IFS. I will let you all know how it performs offroad, So far I've driven it on the road and have notice a bit difference on the RPM in comparison to the 35s, I now cruise @70MPH around 2800 RPM which is not too bad but perhaphs I might feel the difference more going up hill...we'll see!
anyway, here is a picture of my truck on 35s:
And here are some on 37s:
BTW, I have not cranked my torsion bars yet!
Re: I am running 37s now [Re: cap510] #787436 02/08/07 01:34 AM
DougH Offline
Mitsubishi Forum Moderator
How big of a body lift are you running now?
You are testing the limits now for sure!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: I am running 37s now [Re: cap510] #787437 02/08/07 01:37 AM
Chris_Rob Offline
Am running the same tires on mine. Am running 5.29:1 diffs - what are you using? Mine goes better than I expected. I'm going to have to trim the rear of the front fenders, even though I've got a 3" body lift and have cranked the suspension. Think it's because my rims have a 70mm backspace.
'94 LWB 2800, 91 SWB glass-top 2500, 92 SWB soft-top 2500
(You can NEVER have too many Mitsi's!!)
Re: I am running 37s now [Re: cap510] #787438 02/08/07 01:44 AM
3
3esso Offline
Nice Tank man
I have found my self a new wallpaper <img src="/forums/images/graemlins/cheers.gif" alt="" />
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Re: I am running 37s now [Re: DougH] #787439 02/08/07 01:49 AM
cap510 Offline OP
3" BL and 2" longer springs in the back!
yep, if it does not work right I have my 35s sitting in my garage just waiting to go back on! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: I am running 37s now [Re: cap510] #787440 02/08/07 01:51 AM
Scottie2113 Offline
wow man, what gears are you running in your diffs??? I hope 4.90?!?! anyway, hopefully we can wheel our trucks together sometime this summer before I go down to Iraq.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: I am running 37s now [Re: cap510] #787441 02/08/07 01:53 AM
Scottie2113 Offline
is the width of the 37's still 12.5"?
also, with the 3 inch body lift, did you have to extend your t-case shifter and or anything else?
Re: I am running 37s now [Re: Chris_Rob] #787442 02/08/07 02:11 AM
cap510 Offline OP
I haved installed 4.90s R&P and the 3.15TC gears.
At one point I was considering swapping axles with the smaller rear diff (3.0 V6) so that I can install 5.29s but eventhough the on-road performance might have been better I would probably be snaping axles often offroad running 37s. I know the AU boys have snap a few running only 35s.
I don't really need the 5.29s on the freeway (yeah it will be nice to have them) the engine makes up for the lack of gears, it pushes enough power to cruise at a good speed and the 4.90s definitely help. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Riding on 37" MTRs
Re: I am running 37s now [Re: Scottie2113] #787443 02/08/07 02:17 AM
cap510 Offline OP
Yes, the the tires are 37x12.5x15 mounted on 15x10 with 3.5" of BS. My 35s ride on 15x10 with 2.5" of BS. I figured I go with a more moderate offset to minimize stress on the suspension.
I did have to extend some things with the 3" BL such as Shifter, Heater hoses, brake lines, etc.
Riding on 37" MTRs
Re: I am running 37s now [Re: cap510] #787444 02/08/07 02:22 AM
Scottie2113 Offline
wow man, nice job! yeah, I would stick with the 4.90's and the thicker axle. plus t-case gears give you all you need off road I would imagine. like I said, I am looking forward to maybe wheeling with you this summer before I deploy, we'll see if I am ready.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6442 MB (Peak: 0.7697 MB) Data Comp: Off Server Time: 2026-06-10 07:23:48 UTC
