WHAT and WHERE IS the CRANKSHAFT SENSOR on a 97 sidekick? They say I need one to pass SMOG
#787529
02/08/07 07:56 AM
Re: WHAT and WHERE IS the CRANKSHAFT SENSOR on a 97 sidekick? They say I need one to pass SMOG
[Re: hogair1]
#787530
02/10/07 09:40 PM
The Crankshaft Position Sensor (CKP) is used to sense the speed and position of the crankshaft for ignition timing control by the ECM. It is located on the front flange of the oil pan. It will have a two wire lead coming off it to a connector. For a quick check, the resitance between the two terminals of the connector should be 360-460 ohms. The CKP was only used on the 96-98 1.6L engines.
Ridgecrest, CA 2000 Tracker 2-dr
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5834 MB (Peak: 0.6307 MB) Data Comp: Off Server Time: 2026-07-16 08:51:40 UTCValid HTML 5 and Valid CSS
