Re: Oil pressure sending unit interchange? #787570 02/12/07 02:03 AM
dh515 Offline
Thanks for the info. I ordered one as none of the local Kragens had it in stock. I'll advise if it works.
Re: Oil pressure sending unit interchange? #787571 02/12/07 02:51 AM
Stevie Offline
Mine didn't have the ground terminal on it like the one pictured, but it still works the gauge fine.
'80 4X4 Longbed
Re: Oil pressure sending unit interchange? [Re: Stevie] #787572 02/12/07 07:33 AM
It looks like a ground terminal but I cannot see why there would be one since the sender screws into the block and gets it ground from there. I think it is because that sender is used on many different cars that have different style connectors.
The connector on my 1988 was a dual style. It had a typical push on on the end and a slide on on the side. The push on was what was used for my old oil pressure switch. With the new sender I used the side of the connector and slid it on.
Re: Oil pressure sending unit interchange? #787573 02/14/07 09:59 PM
dh515 Offline
I have a 1988 22R pickup. I put in a 1987 4Runner 4 cylinder SR5 cluster in the pickup. It was a Yazaki cluster.
I bought this sender from Kragens and the oil pressure gauge worked fine.
Ok, I received and tried this sender today. Still no go. <img src="/forums/images/graemlins/frown.gif" alt="" />
When I ground the gauge, the needle rises to almost the top. I checked the resistance on the gauge and it checks out ok. Anybody have any ideas? I've tried three different senders now and the gauge still doesn't work. The tests I performed on the gauge are from the FSM and would seem to indicate it and the wiring to it are ok. TIA..
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6030 MB (Peak: 0.6769 MB) Data Comp: Off Server Time: 2026-11-03 13:35:25 UTC
