Need help with 89' 3.0L coolant lines!!! Help! #787629 02/08/07 06:18 PM
I've been having some coolant leaks in the last while....nothing of big concern (lower hose). Early this week, I started losing quite a bit more from the back of the block, on the left side as you are looking at it from the front.
I got it pressure tested yesterday (thought maybe a head gasket) but it turns out to be a tiny (~5" long) rainbow shaped hose on the very back of the block, in front of the firewall. It defintley has coolant in it, but I have no idea what it is or what it does.
Any ideas? Anything will help at this point.
thanks.
<img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Need help with 89' 3.0L coolant lines!!! Help! #787630 02/08/07 10:55 PM
dogtoy Offline
Used for the temp sensor, and part of the bypass if I'm not mistake. It's going to be a pita to get to unless you remove the plenum. Easy otherwise, you do have to buy the preformed shape for replacement. If you do not, the hose kinks and will not work properly. Shouldn't be much more than $20 or so from the dealer.
There is also the bypass that runs under the intake manifold, if you are getting down to it, good idea to just buy both upper and lower intake gaskets, (genuine toyota preferred), the little "rainbow" hose as you called it, and take the plenum and intake off to take a good look at what's happening. If the bypass is leaking, you will kick yourself for not fixing it the first time. The bypass does not use any gaskets if I remember correctly, just silicone, so make sure you have a tube of that hanging around also.
Here is a link Cooling System
If you look at the top of the diagram you will see that hose you are talking about. Just to the right, see the arrow pointing down into the bypass? That's a metal pipe that exists under the intake, if you remove the plenum it will be more apparent, and not much more labor at all to fix it. Just label all of your vaccuum hoses, take pictures, whatever, but after that mess of hoses, it's just a matter of removing nuts/bolts, and parts. There is a sequence to removing the intake manifold, look at the fsm at the top of this forum for more info......Have fun
2014 FJ
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.007s) Memory: 0.5878 MB (Peak: 0.6355 MB) Data Comp: Off Server Time: 2026-07-16 03:40:24 UTC
