Page 1 of 3 1 2 3
roof rack 2nd gen rodeo #787652 02/08/07 09:16 PM
rodeoredd Offline OP
anyone have a picture of the holes in the roof for the stock roof rack on a 2nd gen rodeo?
or know what they look like?
i know its a long shot....making a safari roof rack and want to reuse the factory holes.
cheers <img src="/forums/images/graemlins/cheers.gif" alt="" />
'99 Rodeo V6 4x4 w/ 8" lift, 33" TrXus MT
4.77, Aussie Locked rear, 8500lb winch, custom rack, custom winch bumper, ProComp lights, 230,000km
http://www.cardomain.com/ride/2231794
Re: roof rack holes 2nd gen rodeo [Re: rodeoredd] #787653 02/08/07 10:37 PM
W
Wayne Offline
Pictures from a 2004 Rodeo:
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB68&Number=908976
Dang it. Pictures no workee any more.
You mean the way stuff mounts into the rail, or you mean if you remove the rails and use the holes that enter into the roof.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: roof rack holes 2nd gen rodeo [Re: rodeoredd] #787654 02/08/07 11:12 PM
visionaut Offline
Redd: Are you looking for a picture, or dimensional placement/locations info for those holes? I can take and send a picture, but could also attempt to measure and give you dimensions. (I'm guessing you want to remove the stock rack rails & cross-bars, and see if you can reuse it's mounting holes to mount an aftermarket rack, true?)
Let me know,
Tom
Zzzzzzzzu.
1998 Rodeo S 4x4 -- 3.2L DOHC V6, 3" Calmini Susp liftkit, 3" body lift, Rancho 9000Xs w/RCX, Superwinch hubs, 33x12.5/15s, +other mods
Re: roof rack holes 2nd gen rodeo [Re: visionaut] #787655 02/08/07 11:59 PM
yup, i am wanting to totally replace with a new safari style rack i will build, but i am doing this to add stength for my boat and plywood, etc. i assume that it would be stronger if out of steel than plastic, eh?
so yeah, any help if you have it would be appreciated. i heard its a PITA to take off and replace the factory rack so if it ain't gonna work, i'd like to know in advance if possible.
so i guess yes to both your answers, a photo to know what i am dealing with and specs to aid in the design of the rack.
cheers
Re: roof rack holes 2nd gen rodeo [Re: rodeoredd] #787656 02/09/07 01:14 AM
W
Wayne Offline
I had to remove the rear half of both rails to slide in the cross members. It wasn't bad at all.
Pop the plastic cover (since I wanted to keep it, not damaging this piece was the hardest part!)
Remove 2 bolts. (If you want to slide a rail end, you remove the endcap with one torx screw)
Repeat other side.
Repeat for front.
Even with a new rack, your limit will be how much weight your roof can take. Although if you haul a canoe, you have to worry more about upward force, not downward force (weight).
Re: roof rack holes 2nd gen rodeo [Re: Wayne] #787657 02/09/07 02:26 AM
any idea of how much weight the roof can handle?
i figure the rack will be in the 40 lb range, my boat is pushing 75.
i have had 8 sheets of drywall on it - that was heavy...
Re: roof rack holes 2nd gen rodeo [Re: rodeoredd] #787658 02/09/07 01:49 PM
A
anubis Offline
our roofs are rated at 200 lbs. More than that and you are a test pilot. <img src="/forums/images/graemlins/scared.gif" alt="" /> Im sure it will probbably hold more but that was the factory number.
Also the stock mounting holes can be found on the inside as well if you just need measurements to start. You would have to remove the head liner. Which yo will probably need to do anyways for your rack.
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: roof rack holes 2nd gen rodeo [Re: anubis] #787659 02/09/07 02:19 PM
200 lbs <img src="/forums/images/graemlins/scared.gif" alt="" /> thats it?
so how can a rig stay on its top with a rollover and not instantly crumple? or why when i was sitting on my roof didn't the truck pooch? i guess it would put strain on other things, like glass.... i know i have a crack in my windscreen and once with a heavy load and a bump it got bigger in front of my eyes....
jeez- i was hoping to be able to atleast be able to stand on my rack, but i am 250 lbs + 50 lb rack = ?????????? <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: roof rack holes 2nd gen rodeo [Re: rodeoredd] #787660 02/09/07 03:12 PM
ISueYou Offline
250 lbs + 50 lb rack = A Full Rack ( Which I personally adore) <img src="/forums/images/graemlins/lol.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350
1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50
1983 Chevy Blazer - Stock - $150
No Car Payments - PRICELESS
Re: roof rack holes 2nd gen rodeo [Re: rodeoredd] #787661 02/09/07 09:57 PM
Bigpoppax2 Offline
I'm sure well spread that it would handle double that.
Is Isuzu going to tell you that you can do that..... <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Joe
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6436 MB (Peak: 0.7691 MB) Data Comp: Off Server Time: 2026-06-07 06:57:39 UTC
