U-Bolt flip and upper shock mounts #787751 02/09/07 12:35 AM
drainsbe Offline OP
I got a Rockstomper flip kit for Christmas and just eyeballing the stock shock setup it appears that I will have to change out the upper shock mounts if I'm gonna keep my rs9000x's, or switch to a really short shock... Is anyone running the rockstomper kit and what did you do? Does someone make a upper shock bracket that can be bolted/welded between the frame rails to give me the extra room to use my current shocks?
Thanx in advance <img src="/forums/images/graemlins/cheers.gif" alt="" />
Dave
86 4Runner, 22R-EB
Re: U-Bolt flip and upper shock mounts [Re: drainsbe] #787752 02/09/07 01:11 AM
4Crawler Offline
You can measure and see what fits in the stock mounts. I know one guy running the old shoks in the new mounts. His old shocks were a little too short with the AAL and longer shackle he installed, so with the shock now atop the axle, it was just about the right length. Otherwise, try Budbuilt for a bolt-on shock mount or this is what I did:
http://www.4crawler.com/4x4/4R_suspension-III.shtml#RshockUpdate
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5879 MB (Peak: 0.6361 MB) Data Comp: Off Server Time: 2026-07-15 02:06:43 UTC
