RE: Headers #787769 02/09/07 01:38 AM
dogtoy Offline OP
I've heard the problems w/ heat from the headers burning through floor boards etc...Is header tape a viable solution?
2014 FJ
Re: RE: Headers [Re: dogtoy] #787770 02/09/07 03:14 AM
Stevie Offline
Don't know about the floorboards. I was concerned with heating something up in the engine bay. With a little bending, I fit the outside half of the stock heat shield/enclosure onto the header of my '80 20R.
'80 4X4 Longbed
Re: RE: Headers [Re: dogtoy] #787771 02/09/07 03:52 AM
Snowtoy Offline
Radiant heat from the header will kill your starter, so you shoul get a starter shield blanket from Summit racing, runs about $24.
Along with the starter blanket I ran heat shielding along the passenger firewall, since there was only 1/2" of clearance between it and the header. A 2" BL or beating of teh firewall would have allowed for more room, however I installed the headers first. IIRC, the extra material from teh starter blanklet worked for all of teh other shielding that was needed. The blanket is good up to 750 degrees of contact heat so it can sit right against the header.
The p-side header also burnt the parking brake lin, melted the plastic coating to the cable and wouldn't disengage the brake. After getting a new cable, I rerouted it and used some heat shielding.
Header tape can solve a lot of heat related problems and reduce engine bay temps, but can also cause header rott which will void a manufacturers warranty.
I have been running the headers now for 3yrs and haven't had any heat related issues, other than the ones mention, however I run an lectric fan which runs all the time, so this may be why.
Re: RE: Headers [Re: Snowtoy] #787772 02/09/07 05:14 AM
dogtoy Offline OP
Good info...Thanks
2014 FJ
Re: RE: Headers [Re: dogtoy] #787773 02/15/07 09:51 PM
IceBlueT Offline
i was wondering how hard it was to install the downey headers on a 3.0. ill be getting them within the next month or two, and wanted to know any problems, tricks or tips to mounting them. thanks. <img src="/forums/images/graemlins/kewl.gif" alt="" />
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: RE: Headers [Re: IceBlueT] #787774 02/15/07 10:07 PM
4Crawler Offline
With a 1"-2" body lift, it'll be easier:
http://www.4x4wire.com/toyota/reviews/downeyheaders/
Re: RE: Headers [Re: IceBlueT] #787775 02/16/07 03:54 AM
Snowtoy Offline
A 2" BL would make it a lot easier, however if you don't want the BL, you could lift passenger's side of the body up off of the frame so you can work through the wheel well. The driver's side is easier to access so you shouldn't have to lift it. Without a BL you should hammer back the firewall about an .5-1" on the passenger's side for clearance
Even with a BL, I would recommend removing the intake manifold so you can get at the top of teh header bolts easier. Removing teh intake manifold should allo you enough to room to be able to pass the passenger side header down from above, and will also help with th removal of teh old manifold and x-over pipe. You may also want to consider using studs instead of bolts. I haven't had a problem with the bolts comming loose yet, but others have.
I would have flangers welded onto the headers or the ball/socket type connectors for ease of removal down the road.
Re: RE: Headers [Re: Snowtoy] #787776 02/18/07 09:33 AM
IceBlueT Offline
What are these? im a little confused... <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6252 MB (Peak: 0.7246 MB) Data Comp: Off Server Time: 2026-07-17 01:13:03 UTC
