Torque converter doesn't lock up #787800 02/09/07 03:05 AM
Don Tibbetts Offline OP
I've had this happen intermittently since I've owned this truck but right now I think its as bad as its ever been. When I start the truck cold and drive somewhere, my torque converter will lock up in OD the first time I get above ~50 mph. Once it unlocks, it will not lock up again until the next time I drive the truck. This is not a big deal on my daily commute but its killing my mileage on the highway. I got about 17 mpg on my last highway trip where I used to get between 19 and 20.
Anybody had this happen or have any idea what may cause it?
97 T100 4WD SR5 - 231K
Re: Torque converter doesn't lock up [Re: Don Tibbetts] #787801 02/09/07 08:02 PM
Kookadala Offline
I thought the torque converter was unlocked when in OD, and only locked up when you hit the go pedal on a hill or push the button on the end of the shifter?
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Torque converter doesn't lock up [Re: Kookadala] #787802 02/10/07 04:12 AM
I may have my terminology backwards. I'll describe what I'm talking about for clarity.
Once I get above 50 mph and the revs drop, it feels like there's a direct link between the engine and transmission. In other words, I don't feel the slipping between the two that I do before that point. If my rpms increase by say 300, my speed increases by 10 mph whereas before its locked up my revs may increase with no immediate change in speed. That is caused by the slipping in the torque converter when its unlocked.
At any rate, mine's not doing what its supposed to and I can only hope its a solenoid or a problem with the valve body or something less costly than a new/rebuilt transmission. Maybe I'll try to do a manual swap if mine's on the way out. Anyone done this?
Re: Torque converter doesn't lock up [Re: Don Tibbetts] #787803 02/10/07 09:39 AM
4
4xGeek Offline
Yeah, sounds like your t/c is remaining locked. Could be a wiring gremlin, could be something far worse... Have you looked at / smelled the fluid yet?
As for swapping in a manual, 1 or 2 from this board have done it - would be basically the same as every 86-95 p/u as well. Just need to add a little more to the shopping cart. <img src="/forums/images/graemlins/smile.gif" alt="" />
Pedal assembly
Flywheel w/ hole for t/o bearing
Clutch
Seem to remember you may have to do something with the throttle position sensor as well... Could be wrong.
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Torque converter doesn't lock up [Re: 4xGeek] #787804 02/10/07 12:35 PM
Yes. I just changed the fluid a couple of months ago. The old stuff looked OK, didn't smell burnt. It had been changed about 25K miles before that by the guy I bought the truck from.
Re: Torque converter doesn't lock up [Re: Don Tibbetts] #787805 02/10/07 08:22 PM
ErikB Offline
Toyota Moderator
An auto to manual swap would be more complicated on these trucks than the earlier ones because the brains for the tranny are integrated into the ECU whereas on the earlier ones they were separate and worked more or less independantly.
http://home.4x4wire.com/erik
Re: Torque converter doesn't lock up [Re: ErikB] #787806 02/11/07 03:29 AM
L
lawnmowerman Offline
Maybe it is a shift solenioid?There is an onboard diagnostic system for the AT.In the FSM they list trouble codes but it says that you need a Toyota hand held tester.It is possible that other hand held testers will retrieve codes but I am not sure.
Re: Torque converter doesn't lock up [Re: ErikB] #787807 02/12/07 03:29 AM
That's what I was afraid of. I wonder how much and what kind of feedback the ECU looks for from the transmission. It may be possible to send it an "I'm OK" message from the transmission but I bet its just not that simple. Its too bad because the slushbox is the only thing I really dislike about my truck.
Re: Torque converter doesn't lock up [Re: lawnmowerman] #787808 02/12/07 03:31 AM
I'm going to read over the parts of the FSM that cover this. I was hoping someone else had experienced this and may be able to offer a suggestion. I'm sure any OBD II code reader would do the trick for pulling codes.
Re: Torque converter doesn't lock up [Re: Don Tibbetts] #787809 02/13/07 04:57 PM
garym Offline
I can give you the RPM's at various speeds for my 97. I know at 70 I am turning just over 2500. Seems like that would be the only way to tell if you are locked, speed vs rpm?
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6393 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-06-07 11:36:33 UTC
