gas leaks
#787950
02/09/07 05:42 PM
i have finally finished my rebuild of my 86 22re and now i have gas driping from one of my injectors and i also have gas squirting out if my fuel filter and i replaced the fuel filter and the o rings with new of each during the rebuild. i cant get the fuel filter to stop leaking but i havent looked at the injecters yet so if u have any idea or have had a problem like this before please help me out i just want to get my toy back on the road again!!!!!
Re: gas leaks
[Re: veach]
#787951
02/09/07 08:55 PM
I actually had a similar problem when replacing my injectors; it turned out that one of the injectors was defective and didn't let the o-ring seat properly. I took it back and exchanged it for a new one and problem solved! The trick is seat the injectors in the fuel rail first and turn them so that you have only a small amount of resistance in any given direction. As for the filter, did you replace the copper washers on both ends? And did you torque the banjo bolts to stock spec? Both of these will cause it to leak. I'd also check the washer/banjo on the rail.
Re: gas leaks
[Re: VanillaTHUNDA]
#787952
02/09/07 09:58 PM
Another thing on the little o-rings on the injectors. Lube them first with some gasoline. Tip from Esquire that did it for me. Also, make sure the wires from the connections hang freely and kida loose. I mis-routed my injector wires at first, and some were uctually tugging at the injector(s), forcing it/them away from straight in.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5922 MB (Peak: 0.6457 MB) Data Comp: Off Server Time: 2026-07-15 12:48:04 UTCValid HTML 5 and Valid CSS
