C223 fuel filter change
#788134
02/10/07 02:35 AM
Hi all. Gonna be changing the fuel filter on my C223 for the first time, and I was curious if there are any tips you guys can give me with regard to air entering lines. I've heard where some people will clamp off the fuel line with pliers to keep this from happening. Any help is appreciated, Thanks.
Re: C223 fuel filter change
[Re: mdp]
#788135
02/10/07 04:10 PM
Hello. I would recommend that you remove the fuel filter and filter mount as a unit......tie the hose from the filter to the IP up so as not to lose the fuel in the line...........remove the water detector and install it into the new filter......fill the new filter with diesel and let it "soak in".........now clean the filter mount well as it has a one way valve in it........check it to make sure you can only blow one way through it..........keep filling the new filter until it will not take any more fuel........screw the filter to the mount and reinstall.......make sure the line to the IP is full of diesel and install................I also recommend to remove the fuel tank top and to blow compressed air back through the fuel line that goes back to the tank......................
This would also be a good time to clean the screen at the banjo joint where the metal fuel line connects to the IP.............just reinstall and fill the hose and line with diesel............
regards, crossbones
1982 Luv Diesel 4X2 1982 Luv Diesel 4X4 1981 Luv diesel 4X2 1983 Isuzu Diesel 4X4 1986 Trooper TD
[Re: crossbones]
#788136
02/12/07 01:08 AM
OK thanks. Sounds like great info.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5945 MB (Peak: 0.6486 MB) Data Comp: Off Server Time: 2026-11-03 13:35:30 UTCValid HTML 5 and Valid CSS
