removing IFS front diff #788376 02/11/07 04:07 AM
F
fly_it_slow Offline OP
Do I need to pull the spindle to remove the halfshafts or will they flex enough to get them past the studs on the diff? I tried pulling them tonight and they really didn't seem to want to clear the studs. Any tips?
If I have to remove the spindle should I start with the upper or the lower arm? Tips?
Also, the Haynes says I need to "pull the side gear shafts from the differential with a slide hammer and adaptor plate." Is this really necessary or is there a workaround?
Thanks folks.
Joa
87 4Runner soon to be getting 5.29s and limited slip
Re: removing IFS front diff [Re: fly_it_slow] #788377 02/11/07 04:15 AM
DRTDEVL Offline
Put the nuts back on the studs, and pound them out.
To remove the stub shafts, just use 2 prybars... Works every time.
Re: removing IFS front diff [Re: DRTDEVL] #788378 02/11/07 05:45 AM
Scerb Offline
Put a jack under the lower balljoint on the side you are pulling to compress the ifs as much as possible... then crank the wheel towards the diff and they should clear fine.
-Scerb
Re: removing IFS front diff [Re: Scerb] #788379 02/11/07 08:14 AM
F
Now why didn't I think of that? smile I'll give it a try tomorrow, thanks.
Re: removing IFS front diff [Re: fly_it_slow] #788380 02/11/07 08:16 AM
F
Oh, any tips on pulling the "side gear shaft" after I have the half shafts off? Is there a clip or something that needs a special puller?
Re: removing IFS front diff [Re: fly_it_slow] #788381 02/11/07 11:08 AM
DRTDEVL Offline
I already answered about the side gear "stub" shafts...
Re: removing IFS front diff [Re: fly_it_slow] #788382 02/11/07 06:00 PM
ZUK Offline
http://www.gearinstalls.com/ifs.htm
mostly stock
Re: removing IFS front diff [Re: ZUK] #788383 02/11/07 06:45 PM
F
Hey, good stuff Zuk. I thought I had been through pretty much your entire page but must have missed that one. Thanks.
And DRTDVL... wasn't quite sure what you meant about, "put the nuts back on the studs, and pound them out", hence the confusion.
Re: removing IFS front diff [Re: DRTDEVL] #788384 02/12/07 03:49 AM
TinyTruck Offline
Wicked good idea on the studs, expecially condiering im running around on a blown front diff
1988 YOAT "Stumpy"
-Lock-Right -Fabtech spare tire carrier
-3in PA BL -Custom Flatbed
-32x11.5 cooper mall-terrains <BALD>
Re: removing IFS front diff [Re: TinyTruck] #788385 02/12/07 09:03 AM
F
Send your diff to Zuk, that's what I'm doing...
(no commercial affiliation BTW)
Joa
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6381 MB (Peak: 0.7607 MB) Data Comp: Off Server Time: 2026-06-22 11:21:22 UTC
