Brake master cylinder cap/lid..help needed
#788754
02/12/07 04:10 AM
I need to replace my brake master cylinder. The only replacements that I have been able to find do not come with the reservior. My old reservior is fine but the rubber insert/gasket that goes inside the lid is torn. I can't find replacement reservior lids/gaskets anywhere. Does any one have a home made solution or know of a supplier that has them?? Is there another mitsubishi vehicle that uses the same master cylinder?? My truck is down until I can get this fixed. Any help is appreciated.
DJ
'88 Raider 232,000 miles
Re: Brake master cylinder cap/lid..help needed
[Re: DJ]
#788755
02/12/07 04:39 AM
90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter 92 bone stock base model beater Parting out 4 more
[Re: TommyM]
#788756
02/12/07 04:59 AM
I checked for a PM but didn't find anything. My email address is [email]bls2dpj@yahoo.com.[/email]
DJ
[Re: DJ]
#788757
02/12/07 07:17 AM
I bought one last year from the local dealer. They should still have them IIRC they're not obscenely expensive.
[Re: DJ]
#788758
02/12/07 04:22 PM
I just replaced mine recently with a cardone select from Rockauto.com. $70 + shipping/handling for a new unit. They also have remanufactured ones for about 1/2 the price after core. Mine came complete with new reservoir and cap. Replacement is very straightforward, just remember to bench-bleed the cylinder before you install it.
Good luck. If you have any other questions, let me know.
Eric W.
[Re: off-roader]
#788759
02/12/07 07:44 PM
I have been told "they are obsolete"...on with the search.
Thanks DJ
[Re: 89IsMine]
#788760
02/12/07 07:46 PM
I could not find a whole unit locally. ALll they offer is the master cylinder no reservior. But I did find the one your talking about. Thanks for the heads up.
DJ
[Re: DJ]
#788761
02/13/07 12:00 AM
Thanks DJ The dealer said they are no longer available? <img src="/forums/images/graemlins/frown.gif" alt="" /> Uh oh.
[Re: off-roader]
#788762
02/13/07 01:14 AM
Uh oh. I wouldn't be surprised if this was a Dodge dealer (note that the vehicle in question is a Raider). A couple of times I've called a local Dodge dealer regarding a part for my Raider and been told (albeit kindly, and with part# help) to go to a Mitsubishi parts counter for the item in question... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Eric W.
[Re: 89IsMine]
#788763
02/13/07 02:07 AM
Good point Eric. Remember all, both the Dodge Raider and the same year Montero's are the same other than minor cosmetic differences.
DJ, did you check at both Dodge & Mitsu dealers for these parts?
