Amigo Transmission #788814 02/12/07 06:33 PM
8
89YellowAmigo Offline OP
The other day my transmission started growling. The growl would increase with the RPMs and not with the vehicle speed. I changed out the transmission fluid and found tons of fine metal powder in the fluid. I'm guessing I somehow managed to chip a tooth on a gear. So I've a couple of questions.
1) The manual says to use 5w-30 motor oil and not gear or transmission oil. Can that actually be right?
2) I'm planning on swapping out the transmission with a used one while I rebuild my current one. What other Isuzu vehicles share the same transmission as my '89 2wd Amigo?
Thanks
'89 Amigo, 2wd
2.3L
Re: Amigo Transmission [Re: 89YellowAmigo] #788815 02/13/07 01:59 AM
strawmyers Offline
Isuzu Moderator
Oh yes... if you put gear oil in there, you'll quickly be hearing growling from the replacement tranny as well. <img src="/forums/images/graemlins/scared.gif" alt="" />
Sean Strawmyer
Re: Amigo Transmission [Re: 89YellowAmigo] #788816 02/13/07 03:23 AM
JLEMOND Offline
ANY 2WD 2.3 ENG VEH, ALL HAVE THE SAME TRANS AS YOURS IT IS CALLED AN MSG, WITH ONE EXCEPTION, THERE WERE A HANDFUL OF THE AMIEGO,S ,CALIFORNIA VERSIONS FOR SOME REASON THAT CAME WITH THE SAME TRANS THAT THE 2.6 USED , IT IS EASY TO TELL, ALL MUA TRANS WERE HYDRAULIC CLUTCH CONTROL ALL MSG TRANS WERE CABLE OPERATED JERRY
Re: Amigo Transmission [Re: JLEMOND] #788817 02/13/07 07:00 PM
8
Thanks Sean and Jerry!
I took a look at my Chilton's last night, and I got a little confused.
It says some of the Trooper IIs (85-91) and pick-ups (85-87) use a MSG-5. It also says some Amigos (89-91) use a MSG-5C, but other Amigos (92-94) and some pick-ups (92-95)use a MSG-5L. Does anyone know the difference between the MSG-5, MSG-5C, and MSG-5L?
'89 Amigo, 2wd
2.3L
Re: Amigo Transmission [Re: 89YellowAmigo] #788818 02/14/07 03:08 AM
JLEMOND Offline
AN MSG 5 IS AN MSG 5 AND THE TROOPER S DI NOT HAVE ONE PRIOR TO 86 BEFORE THAT THEY WERE ALL 4 SPDS , AND ALL 2.3 ENGS HAD THE MSG 5 A TROOPER HAD AN MSG 5T THE T MEANING A TRANSFER CASE ONLY, THERE WERE NO 4 SPDS IN THE TROOPER OR THE PICKUPS AFTER 86 IF THEY HAD A 2.3 ENG OR LARGER , AND ALL 4WD VEH 86 AND LATER HAD 5 SPDS EXCEPT OF COURSE THE AUTOS, THE MUA TRANS WAS USED ON ALL ENGS OF 2.6 OR LARGER , ALL AMIEGOS USED THE MSG IF THEY WERE 2.3 ENG,S AND ALL AMIEGOS USED THE MUA IF THEY HAD THE 2.6 ENG JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-05-29 22:29:14 UTC
