I need to remove starter on 98 Rodeo 3.2 #788891 02/12/07 08:51 PM
sawask Offline OP
I need to remove the starter on my 98 RODEO 3.2!! <img src="/forums/images/graemlins/scared.gif" alt="" />
Any suggestions? The wires are not visible from underneath or from above. Do I have to remove the exhaust system <img src="/forums/images/graemlins/barf.gif" alt="" />?
Are there any links to this procedure ? It's pretty warm in the garage today (25) so I thought I might as well get started on it. Cold front comes in tomorrow.
Any and all help is appreciated.
Tom
Re: I need to remove starter on 98 Rodeo 3.2 [Re: sawask] #788892 02/12/07 09:33 PM
JasonB Offline
uh....i had this lengthy reply wrote up on how to do it and realized i was talking about when I replaced my alternator...not the starter.
I can't imagine the starter being too hard to do. It's probably a molex plug on the back side of the starter, and a single bolt holding on the positive battery wire. Disconnect the battery before playing under there. I watched a guy arc a wrench to a car once b/c they didn't disco the batt first. after the electric is done, then just 2 bolts and you should be starter free.
adding life to my days...not days to my life...and LOVING it.
Worlds best BBQ Rub here...
Re: I need to remove starter on 98 Rodeo 3.2 [Re: sawask] #788893 02/13/07 12:45 AM
litnin Offline
It would be much easier if you disconnect the head pipe
from the manifold on that side.
Also, remove fender flap and you can get to it through
the fender well.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: I need to remove starter on 98 Rodeo 3.2 [Re: litnin] #788894 02/14/07 04:03 AM
A
Amigo-2k Offline
I think your only options are to remove the exhaust or unbolt the engine and raise it a bit.
If you had a 2wd then you wouldn't need to do these things.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6025 MB (Peak: 0.6586 MB) Data Comp: Off Server Time: 2026-11-18 11:46:17 UTC
