Slooow rear window #788924 02/12/07 11:20 PM
CROWBAR Offline OP
94 4-Runner some times the rear window works ok & other times it's super slow & even stops when trying to go in either direction. I first thought it was the cold weather. Any tips on this? I did lube the channel with WD40. Thanks
Re: Slooow rear window [Re: CROWBAR] #788925 02/14/07 06:40 AM
kewlynx Offline
Using which control? OR does it matter. Sounds like dirty contacts.
**ubi apis- ibi salus**
Re: Slooow rear window [Re: kewlynx] #788926 02/15/07 11:58 AM
CROWBAR Offline OP
Either control, same result. The tailgate is rusty, maybe not grounding right?
Re: Slooow rear window [Re: CROWBAR] #788927 02/16/07 03:12 AM
kewlynx Offline
Could be; that seems to be a chronic problem area.
Re: Slooow rear window [Re: CROWBAR] #788928 02/19/07 08:47 AM
F
ForOffRoad Offline
I have the same 4runner as you and I find that this happens in winter only too. I have been told that the rubber seal gets dry and you should only use a certain type of silicone on it???? I have not tried it myself...I just pull up my window.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6066 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-10-24 08:14:25 UTC
