Slooow rear window
#788924
02/12/07 11:20 PM
94 4-Runner some times the rear window works ok & other times it's super slow & even stops when trying to go in either direction. I first thought it was the cold weather. Any tips on this? I did lube the channel with WD40. Thanks
Re: Slooow rear window
[Re: CROWBAR]
#788925
02/14/07 06:40 AM
Using which control? OR does it matter. Sounds like dirty contacts.
[Re: kewlynx]
#788926
02/15/07 11:58 AM
Either control, same result. The tailgate is rusty, maybe not grounding right?
[Re: CROWBAR]
#788927
02/16/07 03:12 AM
Could be; that seems to be a chronic problem area.
[Re: CROWBAR]
#788928
02/19/07 08:47 AM
I have the same 4runner as you and I find that this happens in winter only too. I have been told that the rubber seal gets dry and you should only use a certain type of silicone on it???? I have not tried it myself...I just pull up my window.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6057 MB (Peak: 0.6692 MB) Data Comp: Off Server Time: 2026-07-17 07:48:26 UTCValid HTML 5 and Valid CSS
