no start problem #788951 02/13/07 01:02 AM
jdawg13 Offline OP
hey all
I am new to the board and am in desperate need of help!!
I have a 93 YJ w/4.0 manual trans
i was originally having a sputtering/surging problem,
but now the heep won't start!!
I have done everything i can think of which includes
new MAP sensor
new CPS on trans and under distributor
checked vacuum lines
replace TPS
swapped ignition coil
checked all grounds
has spark
has fuel
cranks but won't start
any help would be great!!
Please HELP!!!!
Jay
Re: no start problem [Re: jdawg13] #788952 02/13/07 02:10 AM
What is fuel pressure, fuel present does not mean suffecient.
Re: no start problem [Re: jdawg13] #788953 02/13/07 02:17 AM
BigJim Offline
What he said! Was it mine I'd spray some carb cleaner in it while attempting to start her... If she pops and tries to run I'd look at the fuel pressure.
Re: no start problem [Re: jdawg13] #788954 02/13/07 04:21 AM
jdawg13 Offline OP
just read the pressure on the rail it read 39 PSI
this is driving me crazy!!!!
Re: no start problem [Re: jdawg13] #788955 02/13/07 05:49 AM
BigJim Offline
Might be the iac... Common to lose that feature..
Re: no start problem [Re: BigJim] #788956 02/13/07 05:55 AM
jdawg13 Offline OP
just started, but doesn't want to stay running
popping and backfiring
the iac replaced 2 months ago?
gonna make sure were at TDC now
still trying....
Re: no start problem [Re: jdawg13] #788957 02/13/07 06:31 AM
cjensen Offline
Check for fouled sparky's. Gas soaked. JMHO.
New sparky's, wires, cap, rotor...etc..?
C. <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: no start problem [Re: cjensen] #788958 02/13/07 06:35 AM
jdawg13 Offline OP
i think the distributor was off a tooth,
will replace plugs etc in AM
gonna take it for a test drive right now to see
it runs and idles pretty good considering plugs are munged up a bit now!!
i'll let you guys know!!!
Be right back!!!
thanks all!!!!!!!
jay
Re: no start problem [Re: jdawg13] #788959 02/13/07 07:16 AM
jdawg13 Offline OP
woooo hoooo !!!!
We have a runner again!!!!
thanks for the help guys!!
i'll change the plugs/wires tomorrow and run it!!!
thanks again
jay
Re: no start problem [Re: jdawg13] #788960 02/13/07 03:42 PM
BigJim Offline
Ok wooo hooo now tell us how the dist got a tooth off in the first place??? Did YOU do it or did it do it all by itself.. I sure hope YOU did it! If it did it all by itself you really have a problem and I would not start her again till I got her repaired correctly.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6353 MB (Peak: 0.7424 MB) Data Comp: Off Server Time: 2026-06-22 07:30:50 UTC
