Rhino liner #788982 02/13/07 02:09 AM
L
Locked_Solid_Toy Offline OP
Do any of you guys out there know how much it cost to get the exterior of toyota truck regular cab Rhino lined. Have any of you guys had it done, it how do you like it.
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: Rhino liner [Re: Locked_Solid_Toy] #788983 02/13/07 03:06 AM
Jake97T Offline
i did my lower quarter panels with line-x, cost me (4 years ago) $180, included the front fenders (bottom 8") all the way back to the end of the bed. i like it alot, low maintenance, no chips in the paint from rocks.
Re: Rhino liner [Re: Locked_Solid_Toy] #788984 02/13/07 04:50 AM
btn Offline
I havent done Rhino or Linex but I am planning on Linexing the bed and the hood with the hood being color coded. I was quoted at about 500$ for the bed and another $500 to do the hood in custom color.
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: Rhino liner [Re: btn] #788985 02/13/07 01:43 PM
A
ADAMan Offline
My Dad had his red toyo rhino lined in the bed. He wanted to get red rhino liner to match, but the salesman talked him out of it. He said after a few years the red turns to pink. The only good fadeless colors he said were tan, gray, and black. That was 4 years ago, maybe they have invented some new fade proof polymers, but I would definately investigate. I would not want a pink bed:o <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Rhino liner [Re: ADAMan] #788986 02/13/07 03:40 PM
grandeyota Offline
Rhino liner fades really fast IMHO.
After 7 years my Permatech looks better than my neighbors Rhino liner after only 6 months. Just something to consider.
Fur clog in the sausage grinder
Re: Rhino liner [Re: Locked_Solid_Toy] #788987 02/14/07 07:32 AM
Snowtoy Offline
Teh price is going to vary from shop to shop, the only common pricing is for the beds. Anything else is custom work and brings a custom price, and there usually isn't any warranty for anything other than the bed. IMO I would get teh line-x, it is a far superior product than the others, yes it costs more, but it is worth the extra money
If you aren't looking to spend several $100, you should look into getting Duraback and roll it on yourself.
The $500 for a line-x'd hood in a custom color is a bit extreme IMO, my buddy only charges $800 to do an inerior, and with a hood there is little very little prep involved. It should be even cheaper if you brought the hood in. It may also be cheaper now than when you got the original quote. IIRC, they have new guns that allow them to add the color at the nozzle, so they don't have to waste a lot of product of a mixed color when they purge the hose.
Re: Rhino liner [Re: Snowtoy] #788988 02/15/07 03:46 AM
A
aj2 Offline
I had the bed of my truck Rhino lined a few years ago and I also paid a bit extra to have them run the liner up over the lip of the bed and down the side about an inch. This covered up the spots where I commonly banged up the paint and let me get rid of my lousy plastic bolt-in bedliner which had sanded down the paint pretty badly (sand and off-roading vibration). I don't remember the overall cost, but it wasn't particularly cheap.
The lining has survived several years of Arizona sunlight. It's not as dark a black as it was, but it has held up well. It gets spots when I spill oil on it (difficult to clean), but a dust storm or running down a dirt road drys that up after a while :-).
The only thing I don't like is that the old plastic bedliner was so slippery that it was easy to slide heavy things in and out of the bed, while the new lining is more rubbery, which prevents stuff from sliding out unexpectedly but requires more work moving heavy stuff around.
Re: Rhino liner [Re: aj2] #788989 02/15/07 09:46 PM
TimsToyo Offline
Here's an idea for you. The next time you need to haul something heavy look up a local sheet metal shop or metal supply house and have them cut you a piece of galvanized 24ga. (or 22ga if you haul really heavy things) a little bit smaller than your bed. The liner will hold the metal and you can slide anything you need in or out. It should'nt cost but about $30 for a piece of metal that big. Just don't forget and drive down the interstate with the metal loose. Sheet metal flys really good. Don't ask... <img src="/forums/images/graemlins/lol.gif" alt="" />
'86 Toyo 4wd
'04 600RR
Re: Rhino liner [Re: TimsToyo] #788990 02/15/07 11:27 PM
Stevie Offline
SO TIM......IT WAS YOU <img src="/forums/images/graemlins/mrt.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" />!!!
Just kidding <img src="/forums/images/graemlins/nana.gif" alt="" />. <img src="/forums/images/graemlins/lol.gif" alt="" />
'80 4X4 Longbed
Re: Rhino liner [Re: Stevie] #788991 02/16/07 01:56 AM
turkbodiddle Offline
I got some do it yourself duro-liner from the local auto store. All you so is prep bed and roll it on. It takes a few coats and about a day or so to dry completely. Overall it ran about 100 dollars for liner and the prep kit which comes with a pan scotch brite and roller.
86 toy 33's custom camo paint dura liner black steels 3 inch lift stock motor
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6410 MB (Peak: 0.7673 MB) Data Comp: Off Server Time: 2026-05-29 16:42:09 UTC
