What size tire will a 2inch lift let me add? #788999 02/13/07 03:28 AM
Macdaddy4738 Offline OP
Like the title says, what size tire can I fit on a 98 TJ with a 2 inch lift?
Re: What size tire will a 2inch lift let me add? [Re: Macdaddy4738] #789000 02/13/07 02:20 PM
DBL_DTY97TJ Offline
31 definately, 32 but might rub a bit when mashed into the wheel well.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: What size tire will a 2inch lift let me add? [Re: DBL_DTY97TJ] #789001 02/13/07 04:42 PM
hm..seems pointless then, as I have 31's on it already with no lift at all.
Re: What size tire will a 2inch lift let me add? [Re: Macdaddy4738] #789002 02/14/07 12:04 AM
DBL_DTY97TJ Offline
Well then 2" lift should allow 33's if you don't rub with 31's when it's stuffed up in there. Mine just make it with the BB and BL when it's got a wheel off the ground sitting on one tire - esp. if it's a rear tire.
Re: What size tire will a 2inch lift let me add? [Re: DBL_DTY97TJ] #789003 02/14/07 01:15 AM
the 31's dont rub at all, and even look small for it. Me and my dad figure we could fit 32's in it with no problem of rubbing and still have some articulation.
Im wondering if maybe I already have a kit on it and just dont know it? I dont see anything out of the ordinary, and the owner didnt mention anything about it.
Re: What size tire will a 2inch lift let me add? [Re: Macdaddy4738] #789004 02/24/07 12:26 AM
CoronaJeeper Offline
If it's already got a BB (budget boost), you will see a poly-type 2" spacer between the top of the springs and the spring seat. It's easy to see on the front. My '98 runs 31's with a 2" spacer and there is tons of room, could prolly run 33's without much problem.
Corona <img src="/forums/images/graemlins/cheers.gif" alt="" />
'98 TJ, 4 cyl., auto
31" AT KO's on rockcrawlers,
custom bumpers, Hellas
2" Teraflex lift, no top,
no doors, no problem.
Re: What size tire will a 2inch lift let me add? [Re: CoronaJeeper] #789005 02/26/07 05:11 AM
what color will it be?
Re: What size tire will a 2inch lift let me add? [Re: Macdaddy4738] #789006 02/26/07 04:48 PM
Chris72 Offline
Black or Red are the most common colors for the spacers that I've seen. Depends on the brand of the lift.
Re: What size tire will a 2inch lift let me add? [Re: Chris72] #789007 02/26/07 07:43 PM
i'll check it when I get to see it again.
I have to park it like 2 miles away up here, kinda blows..
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6229 MB (Peak: 0.7087 MB) Data Comp: Off Server Time: 2026-07-13 03:41:38 UTC
