blazer stalls while braking, turning, stopping, and hitting a bump #789038 02/13/07 04:27 AM
4
4mudder Offline OP
ok heres the problem, while turning, stopping, hitting any object or imperfection, going uphill my engine sputters and the check engine light flickers untill the truck stalls. I cleaned the recently replaced fuel filter and checked the fuel pump and based on what i remember fromt the last time i looked at the pump it looks the same, ie: hoses all attached pump functioning etc. Does the return line stop after passing thru the top of the pump/sending unit housing? thanks in advance for any help.
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
Re: blazer stalls while braking, turning, stopping, and hitting a bump [Re: 4mudder] #789039 02/13/07 04:28 AM
52degrees Offline
How many miles do you have on your Blazer and is the distributor original as near as you can tell?
KG6VNX
Re: blazer stalls while braking, turning, stopping, and hitting a bump [Re: 52degrees] #789040 02/13/07 04:39 AM
4
4mudder Offline OP
120K, looks original as far as i can tell
Re: blazer stalls while braking, turning, stopping, and hitting a bump [Re: 4mudder] #789041 02/13/07 06:43 AM
52degrees Offline
Remove the dizzy cap and check for lateral play in the rotor. If there is really any at all it's going to cause problems. I had one last week that would actually touch the outsides and short the whole thing out. No fuel and no spark all of a sudden.
KG6VNX
Re: blazer stalls while braking, turning, stopping, and hitting a bump [Re: 52degrees] #789042 02/16/07 01:09 AM
4
4mudder Offline OP
thanks ill check it out
Re: blazer stalls while braking, turning, stopping, and hitting a bump [Re: 4mudder] #789043 02/26/07 12:15 AM
4
4mudder Offline OP
update. I found the culprit. The previous owner had for some reason jumped the control wire for the fuel pump into the fuse box and the poor connection came loose. so with a little finess the prob is fixed. thanks guys
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6064 MB (Peak: 0.6753 MB) Data Comp: Off Server Time: 2026-10-21 19:15:31 UTC
