2.6L Bore measurement-Should I get it bored? #789117 02/13/07 05:24 PM
MotoXman Offline OP
Here is the newest dilemma. I got the head off and found my 2 low compression cylinders intake full of carbon which should be why it was spitting fuel back up through the carb at around 3000RPM. The intake valves must have not been closing all the way to let this happen. I got an inside mic from work and my friend and i took several seperate readings. We got between 3.609 - 3.611. We measured at the bottom of the cyl (as far down as i could reach), mid way down, and about 1/16 of an inch from the top where the piston stopped and got mostly 3.611 most of the time. I also measured in both directions and it doesnt seem out of round at all. the haynes manual says stock cyl bore should be 3.59 and i have 3.611, dif .021. I do see some slight cross hatching left in the cylinders and found out someone already did the BSE kit. Where should i go from here guys? Rebuild or just put the new clearwater (mech valve) head on?
87 Dodge Raider M/T 2.6L, Clearwater Head, Pacesetter Header, Weber Carb, Still working on it!
Re: 2.6L Bore measurement-Should I get it bored? [Re: MotoXman] #789118 02/13/07 05:50 PM
Jimbotsi Offline
Did a ridge form at the tops of the cylinders? That scoring/ scratching from the rings and out of round would be the only concerns to have in a block. I'd say clean it up real good and bolt the new/ refinished head on.
87 Monty SWB 208k currently immobile: SOME RUST
89 Quest 61k slightly original
DD---> Integra Rust bucket (gone but not forgotten)
02 BMW M5
Re: 2.6L Bore measurement-Should I get it bored? [Re: Jimbotsi] #789119 02/13/07 05:54 PM
MotoXman Offline OP
The only ridge that was there was from carbon and it was very thin. I carefully scraped it away to make sure it wasnt a metal ridge.
Re: 2.6L Bore measurement-Should I get it bored? [Re: MotoXman] #789120 02/13/07 08:40 PM
MotoXman Offline OP
Any more opinions on how far I should go with this or should I just put it all back together like Jimbotsi said to do? I value your guys opinions I would just like some sort of consensus. Also the pistons that are in there say 50mm on top.
Re: 2.6L Bore measurement-Should I get it bored? [Re: MotoXman] #789121 02/13/07 09:16 PM
Your apparent mid-day post should be given a little time for the other FOrum member to read and reply. Remember 'haste makes waste' as this could apply to your time and $$.
Re: 2.6L Bore measurement-Should I get it bored? [Re: rxinhed] #789122 02/14/07 01:06 AM
IF your measurements are good enough, and there's no wear on the thrust side.... No I just can't do it.
If a machine shop with a bore gauge says it's ok, I'd do it. If ALL the honing pattern is still visible, I'd do it. Otherwise, no...
Re: 2.6L Bore measurement-Should I get it bored? [Re: fasteddy] #789123 02/14/07 01:53 AM
BTW, Oyaji Jon still has his engine for sale in L.A. Check for his ad...
Re: 2.6L Bore measurement-Should I get it bored? [Re: rxinhed] #789124 02/14/07 05:14 AM
E
Engine_Machine_Ser Offline
std bore= 3.5875 normal clearance is .001-.0015, you need to mic the pistons also. the 2.6 cylinders do not wear much, but you have to decide if you will re-ring or not.. perhaps try a hone and see when it cleans up. the most wear is at the top. thats when compression is highest and the most pressure is on the rings.
randy
Re: 2.6L Bore measurement-Should I get it bored? [Re: Engine_Machine_Ser] #789125 02/14/07 08:08 AM
MotoXman Offline OP
If I did the rebuild what pistons and rings setup would you guys suggest that will hold up for the long term.
Re: 2.6L Bore measurement-Should I get it bored? [Re: MotoXman] #789126 02/15/07 07:27 AM
MotoXman Offline OP
I dont know if I should go federal mogul, Hyper u`s, or spend the money on forged (Wiseco)which i dont think i need for a pretty much stock setup?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6394 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-06-17 10:39:34 UTC
