All kinds of problems!!!!!
#789279
02/14/07 03:49 AM
Well about 2 days ago my brake light, battery light, and A/T light came on. It was really cold the night before. The truck started up fine but the radio would go off and on. then when i gave it a little gas, the lights would go off. then they would come back on when i let off the gas. So I went to autozone and they checked my battery. they said it was good but it had a low charge. they couldnt test my alternator at the time because the machine was broke. But today when i turned it off it wouldnt start back up and wouldnt go into neutral (automatic) to tow it. so WTF is the problem. Is it the alternator and why wont it go into N. thanks WOODY
94 Yota, ext cab, V6, 4x4, 4in pro comp lift, 3in body, 33" BFG A/T
Re: All kinds of problems!!!!!
[Re: W69DY]
#789280
02/14/07 04:34 AM
Think you got problems, check my post below.....never mind that we are getting pounded with snow up here in the colonies. Anyways to me it sounds like your alt is gone and now your battery is dead. Not sure about going into neutral but does your vehicle require the brake pedal to be depressed before shifting to R and then to neutral.
Keep the Shiney Side up. Support our troops.
[Re: canuck]
#789281
02/14/07 05:27 AM
try to get a load test done on the alternator...its common problem when the brake and alt light come on together
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: W69DY]
#789282
02/14/07 06:32 AM
I sent this link to Canuck too http://www.4x4wire.com/toyota/maintenance/alternator_brushes/On the rig not going into N or starting; check two things; One, the stop fuse; if you don't have that signal, you'd have to use the park override to put into neutral or park to start it. Check the neutral switch adjustment on the tranny. I imagine with all the snow ppl are busting thru right now that a few things might be getting knocked loose or out of alignment. We've got the service manuals stickyd here for your use. That one for the 93 is suitable; just be aware there is 22RE and 3.sl0w info, so mind what you're looking at.
[Re: kewlynx]
#789283
02/14/07 07:31 AM
im not saying that this is the problem, but with my truck, the positive cable running out of the battery to the fuse box mounted on the passenger side of the engine bay kept getting pulled out. i have all of the same symptoms, except the problem getting it in and out of park (mine is a manual). if i would shut it down, i wouldnt be able to start it back up. just tryin to give some possible help. good luck. <img src="/forums/images/graemlins/cheers.gif" alt="" />
formerly 277000_yota Old enough to know better, but still to damn arrogant to care... ]www.cardomain.com/ride/2614269'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P) '98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
[Re: IceBlueT]
#789284
02/14/07 03:12 PM
thanks guys i will try replacing the alternator this weekend and see what happens again thanks WOODY
[Re: W69DY]
#789285
02/14/07 06:16 PM
Easy/Free tech tip!!
Use a screwdriver to test the Alternator while it's running. Put the screwdriver on the back of the alternator. If the alt is charging it will act like a magnet and attract the screwdriver or any other metal object. It won't tell you exactly how much it's charging like a volt meter but it will let you know whether it's low or not charging at all.
'86 Toyo 4wd '04 600RR
