Thermostat Questions #789440 02/14/07 07:34 PM
Dirtybeerguy Offline OP
I recently rebuilt my 94 3.0 Pickup due to overheating, but I'm now wondering If Im hurting or helping matters by what I did. I took the guts out of the 165 degree thermostat, thinking now it will never go bad nor will the motor see harsh temps!! Yes, it takes longer to heat-up, but I have noticed excessive fuel-consumption and was told that by running the thermostat wide-open doesn't let the computer adjust correctly always shooting fuel till it reaches a certain temperature. Any thoughts???
Re: Thermostat Questions [Re: Dirtybeerguy] #789441 02/14/07 07:38 PM
4Crawler Offline
Yes, excessive fuel consumption is common with no t-stat on an EFI engine. ECU is trying to get the engine up to proper operating temps by richening up the fuel/air mix. Run the proper temp. t-stat and fix whatever other cooling system issues you aree masking by not running a t-stat.
Re: Thermostat Questions [Re: 4Crawler] #789442 02/14/07 07:54 PM
Thanks I'll do it ASAP!! I'm in WV, currently having a pretty good snow- so I'll wait till better day! Suffer gas loss
Re: Thermostat Questions [Re: Dirtybeerguy] #789443 02/14/07 11:28 PM
missouriman Offline
see 4 crawlers site about thermo's temp over shoot.
get a factory one, make sure it says toyota.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6005 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-06-17 01:55:07 UTC
