E-Locker retrofit ? #789449 02/14/07 09:48 PM
Kutter Offline OP
I have read the tech article about retrofiting an e-locked rear into a non e-locked axle housing. I did not notice where the article said what vehicle type or year he was actually installing it in.
I want to put one in my 1995 V6 4Runner. Anyone know if this technical article pertains to my proposed installation?
Also a newb question. What is the undesirable characteristic of auto or other lockers on snow and ice? I read numerous comments about avoiding using them in these conditions. Aussie locker has this caution plastered all over there web page for their locker.
Thanks
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: E-Locker retrofit ? [Re: Kutter] #789450 02/14/07 11:07 PM
DentedTacoma Offline
This is what I hear. Retro fitting may not be worth it since the non trd axle is not the same as the trd axle, getting an ARB locker may be better. It can be done but may be unnecessary as far as work and time put in. As far as non selectable lockers on ice and slick stuff it is because you will break loose easier and the back end has a tendency to be all over the place. It can be remedied by driving style but odds are if you are in snow and ice conditions a lot it is better to have a selectable locker. You will also get faster wear on the rear tires.
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: E-Locker retrofit ? [Re: DentedTacoma] #789451 02/14/07 11:42 PM
Adam F Offline
Totally worth it. You can pick up a used unit cheap. I bought mine for $400.
Here's my install and some links on my page, for my 88 4Runner which would be the same axle as your 4Runner
http://home.4x4wire.com/adamf/88/elocker.htm
97 4R, stock, daily driver
Re: E-Locker retrofit ? [Re: Adam F] #789452 02/15/07 12:31 AM
Kutter Offline OP
Thanks, Nice article on your install. Did you get your locked unit with the correct gears or have to install a set?
Any suggestions on supplier for ring and pinion gear set?
Re: E-Locker retrofit ? [Re: Kutter] #789453 02/15/07 03:59 PM
Jeff the marmot Offline
If you need to drive in snow and ice and still want a locker, you definitely should get a selectable locker instead of an automatic locker. This is because you need open diffs to drive on ice and most snow. But it's very handy to also have the locker available for deep snow. If you have a foot or more of snow, lockers are fantastic and make a world of difference. I drove all over the place with 30" of snow when I used front/rear lockers in December while other 4 wheel drives were getting stuck by following my tracks.
For ring and pinions, two of the companies generally accepted to be good are Yukon and www.precisiongear.com
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6068 MB (Peak: 0.6718 MB) Data Comp: Off Server Time: 2026-06-07 05:03:30 UTC
