3.0 Valve cover gaskets and coolant leaking #789460 02/14/07 10:39 PM
U
USMCTRD Offline OP
I seem to remember someone having a fix for the leaking valve cover problem. What is the best gasket to get-Toyota? or does it matter?
The coolant is coming from the back of the engine. I just pulled the plenum off and most of the heater hoses. None of them seemed to be too bad. I'm hoping its not a freeze plug. I figured since I had the plenum off I might as well change the valve cover gaskets.
88 V6 4Runner, 2" 4Crawler body lift, 2" suspension, 32x11.50 Pro Comps
Re: 3.0 Valve cover gaskets and coolant leaking [Re: USMCTRD] #789461 02/15/07 06:55 PM
U
USMCTRD Offline OP
Anybody?
Re: 3.0 Valve cover gaskets and coolant leaking [Re: USMCTRD] #789462 02/15/07 07:28 PM
1
1FastSS Offline
I used Toyota gaskets. They worked. Just make sure and put a dab of the black sealant in each corner just befor install. Clean the serface good as well.
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: 3.0 Valve cover gaskets and coolant leaking [Re: USMCTRD] #789463 02/15/07 10:58 PM
maxxis85 Offline
Well on my 3.0 i used to have a coolant leak behind the motor and it waould lightly steam through the wiper cowl. I was like WTF. It ended up being the hose behind the intake manifold, it comes out and goes right back in the intake trhough the hose. The hase was bad and developed a leak, damned thing almost burned my motor, it was (ill fix it later deal) but thats where mine was leaking from, so it can give you a place to look at.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: 3.0 Valve cover gaskets and coolant leaking [Re: USMCTRD] #789464 02/16/07 03:58 AM
Snowtoy Offline
For some reason teh passenger side valve gasket always leakes regardless of oem or not. My sister had hers replaced at the dealer, and I replaced mine at home after doing teh heads, and both passenger gaskets leak. When I pull mine I am going to use some sealant along the outer edge, the place they tend to leak.
Re: 3.0 Valve cover gaskets and coolant leaking [Re: Snowtoy] #789465 02/16/07 08:51 AM
Myredyota Offline
I have to re-do mine. It has been about 3 years. <img src="/forums/images/graemlins/baby.gif" alt="" />
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: 3.0 Valve cover gaskets and coolant leaking [Re: Myredyota] #789466 02/19/07 07:05 PM
U
USMCTRD Offline OP
I was going to replace all the heater hoses but the dealership was to expensive-big suprise. I just took some hoses off, wire brushed the male ends, got new hose clamps and tightened some things down. It hasn't leaked yet. I also put some spray-on gasket sealer on the valve cover gaskets along with red silicone on the corners. I'll tell ya'll if it works or not.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6176 MB (Peak: 0.6914 MB) Data Comp: Off Server Time: 2026-06-07 09:56:15 UTC
