92 vs. 95 Trooper #789594 02/15/07 03:33 AM
BajaZu Offline OP
I was wondering if anyone knew any differences between the two different years of troopers. I know they both have the same engine (6DV1) SOHC but besides that what about suspension, and are the engine parts interchangeable? Assuming they are the same engine they would be... Any info would help...
1995 Trooper, 4.77 Gears, custom Aluminum body mounts
Re: 92 vs. 95 Trooper [Re: BajaZu] #789595 02/15/07 04:03 AM
langforg Offline
Not many differences at all. I think 95 was the start of OBD-1 engines. Also, if the 95 came with the factory fender flairs I think it had a little bit wider axles.
Brad
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: 92 vs. 95 Trooper [Re: langforg] #789596 02/15/07 04:55 AM
Richard Saylor Offline
It would have been start of OBD-II not I. <img src="/forums/images/graemlins/wink.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 92 vs. 95 Trooper [Re: Richard Saylor] #789597 02/15/07 07:59 AM
langforg Offline
oops. Thanks for the correction.
Re: 92 vs. 95 Trooper [Re: langforg] #789598 02/15/07 01:14 PM
Bigpoppax2 Offline
Wasn't it 96 when the change to OBD-II. I just remember Mark saying that's why he got his 95 was because it had the updated dash and wider axles and also it didn't have OBD-II.
Joe
Re: 92 vs. 95 Trooper [Re: Bigpoppax2] #789599 02/15/07 01:21 PM
litnin Offline
Joe
Yep, '96 was the mandatory year for ODB2.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: 92 vs. 95 Trooper [Re: litnin] #789600 02/15/07 04:05 PM
Joe
Wasn't sure exactly when they started it ... new it was roughly around there. Was just trying to correct his mistake in wording there mainly. Since OBD-I had been out for a while at that point. <img src="/forums/images/graemlins/wink.gif" alt="" />
84 Honda XL185S
Re: 92 vs. 95 Trooper [Re: BajaZu] #789601 02/15/07 04:07 PM
BigSwede Offline
Changes are there but not major...they widened the stance slightly, which means different upper control arms, lower ball joints, front drive axles, and tie rods compared to 92-94. I assume the rear axle is a little wider too. Most parts remain the same though.
Serenity now!
Re: 92 vs. 95 Trooper [Re: BigSwede] #789602 02/16/07 03:14 AM
W
Wareagle Offline
lots of good reasons for the '95
wide axle (excpet radiant red)
new interior
dual airbags
new AC refrig
no SOTF
Re: 92 vs. 95 Trooper [Re: Wareagle] #789603 02/16/07 07:40 PM
BajaZu Offline OP
I assume that you could exchange the older 92s front suspension with that of a 95 and have the wider front axles correct?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6388 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-07 06:09:50 UTC
