Re: Shifter ball and socket [Re: PETE_YK] #789739 03/01/07 07:51 AM
4Crawler Offline
Lower gears are going to be harder to shift due to the greater differences in ratios. But a good GL-4 gear oil will hep make the synchros work better. GL-4 has the proper friction modifiers to let the syncro rings get enough grip to spin up their gears for smoother shifting. If it only shift harder while moving, then this might be the cause. You can also try double-clutching (or rev-matching) to help sync up the gears faster.
The real trick is to do that with the high-low range on the t-case while moving. Totally a non-synchromesh gear box, but you can shift it while moving. Have had to do that while using low range in heavy traffic, then suddenly have the traffic clear and the speeds pick up and you need to get back to high range without pulling over to stop.
Re: Shifter ball and socket [Re: 4Crawler] #789740 03/01/07 01:07 PM
4x4runner Offline OP
I read a post sometime back, that said the Toyota transmisson were suppose to run 30 weight motor oil. I haven't tried, I use Red Line in my tranny and transfer case.
Re: Shifter ball and socket [Re: 4Crawler] #789741 03/01/07 04:41 PM
bnold Offline
Sometimes have to do the pulling heavy loads in the dodge (heavy being over 9-10 tons).. 1st 2LOW, 2nd 2LOW, double clutch into 2HIGH, Double clutch back into 1st 2HIGH..... It's an art, but I can do it now seemlessly... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Shifter ball and socket [Re: 4x4runner] #789742 03/01/07 05:06 PM
4Crawler Offline
Recommended grades and weights taken from my '85 Owner's Manual:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6104 MB (Peak: 0.6834 MB) Data Comp: Off Server Time: 2026-10-24 03:17:16 UTC
