Converting from 7.5 to 8in rear
#789743
02/15/07 06:43 PM
Well my brother broke 2 axles and now my dad just broke something so the driver side axle shaft won't come out. So it's time to just pony up and convert to the 8in. Question is will it bolt on? We will be going from an axle over to an axle under setup. I'll remove the AAL and possibly go back to the stock shackle if it looks funny. We'll also have to redo the parking brake but that's no biggie. 5 lug to 6 lug will be annoying so we will have to figure out how to convert one side to the other or carry 2 spares.
If you don't remember, this is the 86 2wd that I lifted 5in (3in suspention & 2in bl) cut the fenders and installed 33x12.5s. The combination of 33x12.5s, 4.30s, soft locker, centerforce clutch, weber carb and EB crawler cam is just too much for the 7.5in axle to handle.
Plus if anyone has a full 8in axle sitting around AZ, please let me know.
Any info would be great. Thanks
Josh
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Converting from 7.5 to 8in rear
[Re: ArbitraryNotion]
#789744
02/15/07 07:41 PM
I think there are some 2WDs w/ 8" rear axles. A buddy has an '85 2WD w/ an 8" rear, spring under and 5 lug.
[Re: 4Crawler]
#789745
02/15/07 07:56 PM
Hello Josh, long time no post. I found this on car-part.com $100. Freight should run $75 to $100 on top of that. This is from a 1 TON 2 wheel drive. I am assuming 5 bolt lug, not sure on the ring gear/carrier though. Might wanna give them a call? Take care. 1987 Rear Axle Toyota Truck -4X2 SGL.WHLs,1 TON 4:30-1 RAT G0185 $100 Don and Hanks Highway Auto Parts USA-MI(Roseville) Request_Quote 1-800-833-6177 Request_Insurance_Quote *NEW*Live Chat
[Re: Staceman]
#789746
02/15/07 08:35 PM
Woot!
I called and they are pretty backed up right now. Really nice lady on the phone said she'd check to make sure it is still there and get a shipping quote to me prolly today maybe tomrrow due to a funeral.
Yep, haven't been posting much since the truck just sits now. Company car is just too easy to drive. Seems like every time I want to drive the truck I gotta charge the battery and change the oil. Gets kinda expensive to take it out for an afternoon. I've also been rather sick for the last 6mos. Dr might have it figured out but running around in the cold forest hasn't been high on the list of things to do. That and laying in the snow to change the oil.
I still have the same tank of gas in it from June... of 05... Good thing its premium from mobil with stabil in it. It started and ran just fine in November when I last had it out. Prolly should go tank it up soon.
Thanks for the lead! I was only looking in AZ but it makes sense to pay for the shipping when the cheepest 4wd one here in AZ is $350 and has 4.10s and many other issues.
#789747
02/15/07 11:01 PM
8" 2wd rears aren't too hard to find, if you know where to look. every '78 or older 2wd truck i've seen has an 8" with 4.11 or 4.375 gears. as mentioned, the 1 tons had them as well with 4.10s or 4.30s, and oddly, 4 speeds seemed to have them, almost always with 3.08 gears.
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#789748
02/16/07 02:08 AM
8" 2wd rears aren't too hard to find, if you know where to look. every '78 or older 2wd truck i've seen has an 8" with 4.11 or 4.375 gears. as mentioned, the 1 tons had them as well with 4.10s or 4.30s, and oddly, 4 speeds seemed to have them, almost always with 3.08 gears. Read somewhere that all 4 speeds had them. I know my friend's 89 2WD base everything (R.I.P.) had one.
[Re: stock87]
#789749
02/17/07 05:58 AM
Hey Josh,
good to see you on the board.
Yup, I swapped a 2wd 8" into mine so I could use the 3rd's from a 4wd. Since then I've converted to 4wd. I still have that axle though. Has 4.10's in it now. Now that I think about it, I changed it to a spring-over perch setup, so some finagling with the e-brake cables would be necessary. IIRC, the 4wd axles are not the same width as the 2wd 8" axles so swapping the axle shafts may not work to maintain the 5 lug pattern. I haven't measured the axles themselves, but I have one of each and can do that if you'd like.
Todd
1986 Pickup extracab longbed "Woody edition" SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD" 94 2wd v6 extracab 04 Outback Wagon- wife's/family car
[Re: Staceman]
#789750
02/28/07 04:01 PM
Grrr...
Was wondering why they never called me back...
Said they won't ship to a residence, semi-truck would show up and expect a forklift. Then again, my dad got the longblock engine off the semi by himself that EB shipped me. The truck driver wouldn't lift a finger to help so my dad did it himself.
Any ideas?
#789751
02/28/07 04:39 PM
........... 5 lug to 6 lug will be annoying so we will have to figure out how to convert one side to the other or carry 2 spares................
Josh How about carrying the spare of your choice and one onboard aluminum 5 to 6 or 6 to 5 adapter ring?
[Re: stock87]
#789752
02/28/07 09:56 PM
8" 2wd rears aren't too hard to find, if you know where to look. every '78 or older 2wd truck i've seen has an 8" with 4.11 or 4.375 gears. as mentioned, the 1 tons had them as well with 4.10s or 4.30s, and oddly, 4 speeds seemed to have them, almost always with 3.08 gears. Read somewhere that all 4 speeds had them. I know my friend's 89 2WD base everything (R.I.P.) had one. i'd say that, but i've been messing with toyotas long enough to know that if i did, the next 2wd 4 speed i found would have a 7.5 in it <img src="/forums/images/graemlins/lol.gif" alt="" />
