T100 3.4: low oil pressure when idling at light, only 129k miles #789762 02/15/07 06:58 PM
hartzpad Offline OP
My '96 T100 3.4L shows low oil pressure when fully warm and idling at a stoplight. If i give it any gas at all, even just a few hundred RPM's, the pressure goes up to almost to halfway. I only get low oil pressure when the truck has been run a lot and it is more prevalent in the hot summer days than the cold winter days. The engine is all original with only 129,000 miles on it.
The oil pressure never completely drops off the gauge, but it hovers on the lowest reading sometimes until I get the engine moving again.
These trucks take 5W-30 oil correct? Can I try using some 10W-40 to see if that increases the oil pressure slightly? Any other suggestions?
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: hartzpad] #789763 02/15/07 08:48 PM
Jake97T Offline
10w30 wont change it at operating temp, its normal for the oil pressure to be low at idle.
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: hartzpad] #789764 02/15/07 09:17 PM
wsquaredodie Offline
after 2 3.0's, one with 122k and the other at 155k, both did/do the same thing as yours. I am in upstate NY and use 20/50. If you are really concerned get an accurate guage and check it out...
trafdlo
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: wsquaredodie] #789765 02/15/07 09:40 PM
95T100 Offline
Check your manual, pretty sure that is with the norm. The 2nd and 4th line are where it should be when not at idle (if memory serves correct).
1995 Toyota T100, Rhino Liner, SwayAway Torsion Bars, Bilestien Shocks, Brembo Rotors, Akebono Pads, SS Brakelines, Monroe Steering Stabilizer & TRD/Eaton LSD
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: 95T100] #789766 02/15/07 10:05 PM
hartzpad Offline OP
So there is no need to worry about the engine running out of oil pressure? It sometimes reads right at the very lowest possible on the oil pressure gauge. I didn't know if that meant there was 0 psi or if it is just enough to lubricate while idling?
I find myself bringing the engine up to about a 1000-1100 RPM idle just to bring it up and make myself feel better. I don't need to do that?
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: hartzpad] #789767 02/15/07 11:55 PM
adam Offline
Mine hasn't read like I intuit it 'should' since it broke in. It's entirely common for the dash gauge to read low. I wonder if it might start reading lower in relation to the valve cover gasket fading (or something else; it's a vehicle - things get old and wear out) as it seems mine has read a little lower since I noticed oil weeping out a little at the back end of the covers, but it should not be taken on its own as an indicator of a catastrophic engine failure. I would not (don't myself anyhow) feel a need to keep the engine raced a little at a stop the way you describe.
~Adam
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: hartzpad] #789768 02/16/07 03:17 AM
foxtrapper Offline
Unnerving, isn't it? Yet it's a Toyota truck special, they all do that. Low reading oil pressure gauges is the norm with Toyota trucks.
I did run 10w-40 in mine once, made a faint difference, but not much.
'97 T-100 SR5
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: foxtrapper] #789769 02/16/07 07:43 PM
Honger Offline
This is normal.
When I bought my first T100, it had the same behavior and only 62K miles. I made the replace the sender and gauge before purchasing. It did the exact same thing when new sender and gauge.
Joel
1998 Toyota T100 SR5 ExtraCab 4WD
Re: T100 3.4: low oil pressure when idling at light, only 129k miles [Re: Honger] #789770 02/16/07 10:40 PM
hartzpad Offline OP
Good to know, thanks to all of you for putting my fears to rest. I'll ignore it.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6295 MB (Peak: 0.7323 MB) Data Comp: Off Server Time: 2026-06-07 11:38:01 UTC
