Water pump #789956 02/16/07 07:40 AM
smith123isuzu Offline OP
Can any one please help.........there is anti-freze coming out the p=side of the timing cover...3.2 96 rodeo.....4x4.. no strange noises.....just leakin......I fig that it is the damn water pump....120,000 miles....and a Q's is "Do you have to change/take off the timing belt...or would this be the time that you do this since it has so much to be removed to get a waterpump in!!!!!!! <img src="/forums/images/graemlins/frown.gif" alt="" /> [color:"red"] [/color]
96' Isuzu Rodeo...SaS Dana 44 front & rear. 4.88s',Auburn limited @ both ends, with lot's of other stuff..
Proud member of Cal4WD, TTORA and SN4WD.
Jeepcamping.com
more than just jeep stuff.
Re: Water pump [Re: smith123isuzu] #789957 02/16/07 03:19 PM
BigSwede Offline
Definitely do them together if you haven't done the belt lately...the timing belt drives the water pump so you will be right there. FWIW my water pump went out at 110K...
Serenity now!
Re: Water pump [Re: BigSwede] #789958 02/16/07 05:16 PM
ya ya ya that what the gen pop says too....man this sucks... last time I ck'd on a time belt, the local auto shops where out of stock for it....hopefully that they now how them...the only bad really bad part is this...[Linked Image]
this is what happend two weeks ago...and I haven't quite figurd out how this is going to get done.....any one want to help.....ima in sac....fair oaks..I'll buy lunch and beer and dinner..... <img src="/forums/images/graemlins/smile.gif" alt="" />
Jeepcamping.com
Re: Water pump [Re: smith123isuzu] #789959 02/16/07 05:29 PM
BigSwede Offline
Oh, and if you do the timing belt, definitely also do the timing belt tensioner. They go out a lot, and again it is the same operation to get to it as with the water pump...I wish I had, now I gotta go back in just for the tensioner.
Serenity now!
Re: Water pump [Re: BigSwede] #789960 02/16/07 06:03 PM
ya I was told that too...do all while there...it will save you later....
Jeepcamping.com
Re: Water pump [Re: smith123isuzu] #789961 02/18/07 04:20 PM
BobDole Offline
Definitely do the timing belt, water pump and tensioner all together. It can be a pain to get in there. Especially when the last person to do it (stealership) used king kong and a 20 ft breaker bar to torque the crankshaft pulley nut on (search my posts to find out why I say this).
Search the forum for helpful hints and tricks for changing all the stuff out. There has been quite alot written on it.
Good Luck <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Water pump [Re: BobDole] #789962 02/20/07 10:51 PM
G
garydh2000 Offline
How do you know if the tensioner is going bad? Does it make a bad squealing noise?
Re: Water pump [Re: garydh2000] #789963 02/21/07 03:20 AM
BobDole Offline
Take the tensioner out. Press it in by hand. If you can press it in, it's bad. If you have 120k on it, replace it, or you might be sorry a few months or years down the road. :-)
Re: Water pump [Re: garydh2000] #789964 02/21/07 03:27 PM
BigSwede Offline
In my experience it makes or contributes to a clattering sound that sounds like any number of engine problems from lifter tick to piston slap/knock...but the defining characteristic is that the sound goes away at 2000 - 2500 rpm and above.
Serenity now!
Re: Water pump [Re: BigSwede] #789965 02/21/07 07:13 PM
Thanks everyone for their in-put on the waterpump...today she went to the local shop....waterpump timeing kit..tranny mount and rr break line.....I am still an able to do the work myself.. still with a broken foot.....but I guess that I can justifiy the 800 buck that way for parts and work done...all in a day...ya this shop was the cheapest around.....others hit 1100-1500 to do the same.... <img src="/forums/images/graemlins/scared.gif" alt="" />
Jeepcamping.com
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6412 MB (Peak: 0.7655 MB) Data Comp: Off Server Time: 2026-11-19 23:56:51 UTC
