T-100 ashtray will not stay closed #790129 02/16/07 11:06 PM
Sneaky_Snapper Offline OP
I have a 1997 T-100 with 100,000 miles on it. My problem is that the ashtray will not stay in the closed position. I do not smoke, so the ashtray is barely used. I have emptied out some change, etc. and it still will not stay in the closed position.
What is the mechanism that keeps this baby closed? Is it the plastic rails on the sides? Maybe they have worn a little.
Thanks for your help.
Brad
1997 T100 SR5, X-Cab, V-6, Auto, 113,000 miles, Bilstein shocks
Re: T-100 ashtray will not stay closed [Re: Sneaky_Snapper] #790130 02/16/07 11:49 PM
JohnF Offline
Mine has done that since I can remember. I put strips of velcro on both sides, out of sight. That keeps it closed most of the time, it still pops open occasionally on washboard roads...
Re: T-100 ashtray will not stay closed [Re: JohnF] #790131 02/17/07 12:13 AM
Honger Offline
I use mine for change and it does the same thing... or use to. One day I got really tired of it and took a knapkin and shut the ashtray with the knapkin in the plastic runner (tore off all the overlap)... stays put nicely now!
1998 Toyota T100 SR5 ExtraCab 4WD
Re: T-100 ashtray will not stay closed [Re: Sneaky_Snapper] #790132 02/17/07 03:20 PM
wsquaredodie Offline
Ain't it amazing that the Japs can build such a good truck and have such a wimpy ash tray at the same time? both of my 93's had same problem. Use the paper trick now - gonna try the velcro though. Thanks for the tip
trafdlo
Re: T-100 ashtray will not stay closed [Re: wsquaredodie] #790133 02/17/07 08:56 PM
adam Offline
See, if you guys just stuck to using it for it's designed purpose you'd find the tar buildup from snuffing butts in it keeps it closed just fine <img src="/forums/images/graemlins/notooth.gif" alt="" />
~Adam
Re: T-100 ashtray will not stay closed [Re: adam] #790134 02/18/07 12:05 AM
Yeah but it still does not hold up to the 6.5 inch 50 ring Cubans!!
trafdlo
Re: T-100 ashtray will not stay closed [Re: wsquaredodie] #790135 02/18/07 06:56 AM
CJMT100 Offline
I dunno, I got mine filled with some change and junk and it stays closed..
Re: T-100 ashtray will not stay closed [Re: CJMT100] #790136 02/20/07 07:07 AM
W
Winkel1 Offline
Take the ashtray out, scuff up the side ridges that run in the tracks (with some sand paper) clean it good with finger nail polish remover, put some super glue or clear fingernail polish on them and let it dry. When you install it, it will fit tighter and stay shut better. In time it will wear, but this was a simple fix for mine.
Winkel
98 T100 SR5 4WD
Rhino Liner
Warn Hubs
Mostly Stock
Re: T-100 ashtray will not stay closed [Re: Winkel1] #790137 02/20/07 07:51 PM
marion Offline
I put some black friction tape on the edge of the metal thingy that pops up when you remove it. When installed, it pushes up and the added friction keeps it from opening on its own. It's worked that way for a couple years, but on really rough roads it still opens on occasion.
Re: T-100 ashtray will not stay closed [Re: marion] #790138 02/20/07 09:58 PM
hartzpad Offline
My T100 has 125k miles and the ashtray has never opened, even when jumping the truck. But I don't keep any change in the ashtray either. Does it still pop out if you don't put anything in it? There might be a reason why T100's have those change/quarter holders on the dash.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6378 MB (Peak: 0.7445 MB) Data Comp: Off Server Time: 2026-06-07 04:38:33 UTC
