Do I really need those 4" sway bars? #790208 02/17/07 07:40 AM
F
ForOffRoad Offline OP
I have broken my left sway bar and was just told I don't need to replace them. Won't this put more stress on the rest of the parts on my front end? Has anyone not replaced the sway bars?
Re: Do I really need those 4" sway bars? [Re: ForOffRoad] #790209 02/17/07 07:50 AM
4Crawler Offline
Likely the end link has broken, not that hard to replace, get a used one from the junkyard.
But, if you have not noticed any difference in handling since it broke, you can probably remove the whole bar, as you have not had a functioning one since the part broke. Won't stress the front end, you may feel a little more body roll in turns, but it is a truck afterall, not a sports car. I've not had a front sway bar for about 8 years now.
Re: Do I really need those 4" sway bars? [Re: ForOffRoad] #790210 02/17/07 09:14 AM
Runner-Man Offline
I agree with 4Crawler. If you've been driving around with the link broken, I say remove the entire anti-roll bar. I haven't had one on my '89 for about 3 years now. It's pretty much stock except for Chevy rear springs. A little more body roll, but nothing drastic.
A few years ago I was rear ended by a GMC 3500, and the impact spun me around 180 degrees and pushed me across oncoming traffic. No anti-roll bar, no roll-over, so I've got to say it's pretty safe to remove.
Re: Do I really need those 4" sway bars? [Re: 4Crawler] #790211 02/17/07 05:07 PM
F
Thanks for the info...I really did not want to replace those things.
Re: Do I really need those 4" sway bars? [Re: Runner-Man] #790212 02/17/07 05:09 PM
F
Yes, I don't see much good those sway bars are being only 4" long on each side. I don't notice much of a difference when I am turning or when I am off road. Thanks!
Re: Do I really need those 4" sway bars? [Re: ForOffRoad] #790213 02/17/07 05:47 PM
Jake97T Offline
I know a guy with an 89, 4" lift who spun out in a corner, then caught some traction, rolled it down the side of an embankment...although he was a bad driver... <img src="/forums/images/graemlins/lol.gif" alt="" />, i dont run one either, but im a wee bit wider.
Re: Do I really need those 4" sway bars? [Re: Jake97T] #790214 02/17/07 06:56 PM
Scerb Offline
Not a whole lot is gonna save you once you're sideways in a lifted Toyota. 'cept for a snowbank.. <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
But ya, if you don't mind how its driving right now, you don't need the sway bar. I haven't had mine for a while now too.
Re: Do I really need those 4" sway bars? [Re: Scerb] #790215 02/18/07 12:40 AM
Spacetrucking Offline
Same here, took mine off, no difference at all in my case, am running SwayAway torsion bars.
Having it off helps with the minimal articulation that the IFS does have <img src="/forums/images/graemlins/lol.gif" alt="" />
I would be careful though if you have a high body lift
and big tires.
'86 SR-5 Extra-cab 4 x 4, 2" BL, 33 x 12.5 x 15R M/T on 15 x 8 rockcrawlers ( 3 3/4" BS ), 22RE 5 sp , 4.88's Detroit True-Trac front, V6 open rear, 24 mm Sway-Away + Rancho 5000's, removed sway bar, no-rust south US bed, Ramsey 8000 winch
Re: Do I really need those 4" sway bars? [Re: Spacetrucking] #790216 02/18/07 12:52 AM
BTW for 4Crawler: Roger I can't seem to access any of your very informative web sites, do I have some type of setting on my end preventing this? <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks,
Hugh
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6261 MB (Peak: 0.7289 MB) Data Comp: Off Server Time: 2026-07-17 02:18:55 UTC
