Jeep Dies After Freeway Driving #790246 02/17/07 06:54 PM
josephelk Offline OP
HellO all,
My 89YJ with 5spd that I put a 91XJ 4.0 in dieÆs after I drive it on the freeway to work? After it dies I can compression start it or if IÆm at a light I just start it and it idles fine but when I push the clutch in and slow down to stop again it will die?
Any Ideas
89 YJ, 3.5" Black Diamond Lift, 33" tires, 8000lb Warn, 4.0 91 XY engine swap.
Re: Jeep Dies After Freeway Driving [Re: josephelk] #790247 02/17/07 11:45 PM
BobRowe Offline
Did it ever run properly after the engine swap?
Re: Jeep Dies After Freeway Driving [Re: BobRowe] #790248 02/18/07 01:30 AM
It ran excellent and still does except for after I run it on the freeway for about 10 miles.
Re: Jeep Dies After Freeway Driving [Re: josephelk] #790249 02/18/07 04:22 AM
tomriddle Offline
fuel filter?
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
Re: Jeep Dies After Freeway Driving [Re: tomriddle] #790250 02/18/07 09:34 PM
No I'm getting fuel? I disconnected the fuel line at the fuel rail and it shots gas across the driveway. Last night I was driving home and it just died and I mean died without hesitation. I thought it was the coil so I replaced it and it still will not start? It turns over and just keeps turning over and will not start like the coil wire is disconnected. I'm lost on this one; I have no idea what to do next? Solenoid, ballast resister, CPS or computer?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6046 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-06-07 06:56:33 UTC
