Making longer shackles #790276 02/17/07 09:34 PM
Johnboy Offline OP
I added a winch up front and now the front shackles easily contact the frame when I hit bumps. I need to go a little longer but don't want to change the pinion angle drastically. I have 3/8 mild steel to do the job and think that "wide body" style would be acceptable, but what do I use for the spacer? Any other considerations I should take into account? Would 1.5" longer than stock work?
<img src="/forums/images/graemlins/patriot.gif" alt="" />
-Johnoby
85 4Runner, 4" lift, bumpers, sliders, locker
Re: Making longer shackles [Re: Johnboy] #790277 02/18/07 01:31 AM
missouriman Offline
look for 4crawler on here and just buy his front shackles.
not expensive and really built nice.
I am going to be ordering my second set from him soon. for my wifes truck.. it is a little stiff right now.. grin.
I have the springs, cross over, hydro cylinders.
need shackles front and rear and a steering box to tap....
wife is going to love...... the increased travel, ride quality... lol... easy of turning.. blush.
Re: Making longer shackles [Re: Johnboy] #790278 02/18/07 05:14 AM
Johnboy Offline OP
OK, but that didn't answer my questions. I want to make my own. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Making longer shackles [Re: Johnboy] #790279 02/18/07 05:32 AM
OOP'S Offline
I used some thick walled tubing (.250) and a washer against the spring bushing. What springs do you have, sounds like they maybe worn out.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Making longer shackles [Re: Johnboy] #790280 02/19/07 12:25 AM
4Crawler Offline
I make the wide body shackle spacers out of 1-3/4" round steel rod, they are available separately:
http://www.4crawler.com/4x4/ForSale/Shackles.shtml#OrderingInfo
You can also stack up two slabs of 3/8" steel on each side and grind off about 0.050" off the face to make your own (overall thickness is 0.700").
Re: Making longer shackles [Re: 4Crawler] #790281 02/19/07 02:14 AM
Johnboy Offline OP
Thanks Roger, I thought it was that simple, I just didnt want to miss something.
Springs are 2" lift BDS YJ springs and are not worn out. There just isn't enough shackle travel.
Re: Making longer shackles [Re: Johnboy] #790282 02/19/07 02:22 AM
4Crawler Offline
The YJ springs ae about 1/8" wider than the Toyota, so you'll need to thin the spacers down to match. Just measure the width of the shackle hanger (w/ bushings) and the width of the spring eye (w/ bushings) and halve the difference for the spacer thickness. Ideally you want the side plates perfectly parallel for maximum bushing life.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6173 MB (Peak: 0.7078 MB) Data Comp: Off Server Time: 2026-07-15 19:03:11 UTC
