idler arm to idler shaft torque requirements?
#790316
02/17/07 11:52 PM
I had my 93 rodeo in for an alignment today and on the way home I noticed it still had a little play in the steering. I got home and jacked the front end up and grabbed a hold of the center link and noticed there was a lot of movement. The idler arm looks to be loose where it tightens up to the shaft (not the center link). There is a gap between the two and looks like it needs to be tightened up. My question is should I tighten it all the way up or should there be a space in between? If I need to tighten it up what is the torque specifications? Thanks for any help.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
Re: idler arm to idler shaft torque requirements?
[Re: throwin_roost]
#790317
02/22/07 10:04 PM
I canÆt help you with any actual torque specs û butà
Yes, there should be *some* space between the Idler Arm and the Sector Shaft Cylinderà (roughly) an 1/8 to a 1/4 of an inch (give or take).
This probably only applies if youÆve been 4-wheeling yours pretty hard, but hereÆs another possibilityà
If you are seeing a ælobe-likeÆ movement, where the Idler Arm seems to be moving up-and-down while the steering is in motion (rather than making a clean & even / side-to-side sweep), itÆs possible that you might have a bent Sector Shaft and therefore would need to replace your Idler Relay Lever.
HTH
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5887 MB (Peak: 0.6369 MB) Data Comp: Off Server Time: 2026-06-09 21:59:47 UTCValid HTML 5 and Valid CSS
