Transfer case Problems. #790370 02/18/07 03:34 AM
1
1009 Offline OP
My son just purchased an 89 Raider V6/AT. The transfer case will not shift, as in the shift lever will not move. He bought it from a fella that never put it in 4WD...yeah NEVER. But the rest of the "RIG" is in great shape. Don't suppose the fix for this is as easy as pull the lever out squirt some ATF on the parts and away we go? The tranny works great otherwise. Thanks for your help! Terry
89 Dodge Raider V6 Auto Black n Gold
Re: Transfer case Problems. [Re: 1009] #790371 02/18/07 04:30 AM
LandRaider Offline
Hmmmm Well I'd try yanking on it some. Give it a good pull twards the rear.
Re: Transfer case Problems. [Re: 1009] #790372 02/18/07 05:01 AM
TitusCanbee Offline
Just went through almost the exact same thing with my son's '89 Montero. I could not get the transfer case shifter to move unless I really pushed hard, then it would barely move. <img src="/forums/images/graemlins/scared.gif" alt="" /> What I ended up doing was removing the center console from around the shifter, then removed the floor plate and boot, which exposed the shifter linkage. Sprayed a good quality penatrating fluid right where the barrel enters the transfer case. Really soaked it. Then I moved it to the center and worked it side to side for several minutes. Finally started working it back and forth after spraying some more. When I was done, you could move the shifter with 2 fingers! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Of course, it goes without saying, that the transmission needs to be in Neutral and all preload removed from the drive train for the transfer case to shift.
'89 Montero, '90 Montero, both 3.0s and 4drs.
'08 Chevy HHR
Re: Transfer case Problems. [Re: TitusCanbee] #790373 02/18/07 05:09 AM
LandRaider Offline
Ya might want to change your Xfer case lube after that. No doubt you got some penetrant down in there. Depending on how much....
Re: Transfer case Problems. [Re: LandRaider] #790374 02/18/07 07:22 PM
They are very balky to shift when the driveline has ANY load. I like to be in neutral, foot off the brake, to shift it. Even with the ebrake on, it's tough. Try turning the truck upside down and shake it to get lube on the shifter forks and rails....
Re: Transfer case Problems. [Re: TitusCanbee] #790375 02/19/07 02:57 AM
1
1009 Offline OP
Ok I got a can of liqud wrench and sprayed it on the linkage and as good as I could in the barrel> it freed up a bit I worked with it for about 45mins. It was pretty corroded. but it moves about an 1/8 of an inch fwd and back. I soaked it some more and will let it set over night...but I gotta gut feeling it's gunna need a pros help..can the transfer case be parted from the Tranny? Thanks for the suggestion.http://www.4x4wire.com/forums/images/icons/thumbsup.gif
thumbsup
Re: Transfer case Problems. [Re: 1009] #790376 02/19/07 08:06 PM
It took one of mine a few weeks before it moved smoothly.
if I recall there was a bolt/grub screw in line with the shifter where it enters the case that I sprayed in. That got it to free up quicker.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6216 MB (Peak: 0.6967 MB) Data Comp: Off Server Time: 2026-06-07 11:36:16 UTC
