help oil in antifreeze #790505 02/18/07 07:13 PM
smokn03 Offline OP
i noticed today that i am starting to get oil in my antifreeze.my oil is fine no antifreeze in it.and when you take the cap off of radiator there is a little pressure coming out after the cap has been off a while.so is it a headgasket or maybe timing chain that put a hole in the cover? also starting to get a knocking sound could this have to do with antifreeze problem?mite need to pull a rebuild the whole motor?or maybe just head gasket and timing chain?any info would be appreciated
Re: help oil in antifreeze [Re: smokn03] #790506 02/18/07 08:55 PM
TimsToyo Offline
First pull the valve cover and check the timing chain guide on the driver's side. If it's still there then your timing chain cover should be ok. Next run a compression test and a leak down test on the cylinders to see where the leak is.
The knock shouldn't be from the coolant if it isn't getting into your oil. The knock may be the timing chain.
'86 Toyo 4wd
'04 600RR
Re: help oil in antifreeze [Re: TimsToyo] #790507 02/18/07 09:03 PM
smokn03 Offline OP
thanks i will check that stuff first.also truck only has 135000 miles thought these trucks lasted forever <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: help oil in antifreeze [Re: smokn03] #790508 02/19/07 02:36 AM
smokn03 Offline OP
and how many miles before bottom end needs rebuilt?
Re: help oil in antifreeze [Re: smokn03] #790509 02/19/07 04:44 AM
dcg9381 Offline
Well maintained, 250k isn't abnormal (with at least one HG and timing chain setup).
22REturbo.net
1988 4Runner
Re: help oil in antifreeze [Re: dcg9381] #790510 02/20/07 05:19 AM
smokn03 Offline OP
is a graphite headgasket good or bad seen one on ebay wondering if its junk or normal and can you convert timing chain from 82 22r thats double row chain?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6756 MB) Data Comp: Off Server Time: 2026-06-23 01:15:56 UTC
