87 4Runna surging #790544 02/18/07 09:18 PM
jdawg13 Offline OP
Hey everyone
I have an 87 4Runna with a 22RE in it.
Once it warms up, the idle wil surge up and down when i come to a stop.
I have been told this could be th EGR but is there a diagnostic code or some way of finding out exactly what it is before spending close to $200 for an EGR??
Thanks
Jay
Re: 87 4Runna surging [Re: jdawg13] #790545 02/18/07 09:29 PM
DRTDEVL Offline
How about spending 200 seconds (or less) lowering your idle instead?
The ECU gets a signal from the brake light switch. If the ECU senses IDL from the TPS and Brakes, it checks the RPM. If the RPM is over 1100, it cuts the fuel injectors off. When the RPM drops below 800, it turns them back on. This can cycle repeatedly if your idle is too high, and it would look like 500-1200 rp0m surges... About one per second.
Lower your idle to 750.
Re: 87 4Runna surging [Re: DRTDEVL] #790546 02/18/07 09:41 PM
jdawg13 Offline OP
this may be a stupid question, but is the idle screw on the throttle body?? like a carb?
Re: 87 4Runna surging [Re: jdawg13] #790547 02/18/07 10:26 PM
Adam F Offline
yes
97 4R, stock, daily driver
Re: 87 4Runna surging [Re: jdawg13] #790548 02/18/07 10:29 PM
DRTDEVL Offline
On TOP of the throttle body... Flat tip screwdriver. Looks like a small bottle cap sticking out if the throttle body.
Do NOT touch the screws on the bottom side... This is a totally different adjustment.
Re: 87 4Runna surging [Re: DRTDEVL] #790549 02/18/07 10:53 PM
jdawg13 Offline OP
sweet i'll try that and see what happens.
thanks
jay
Re: 87 4Runna surging [Re: jdawg13] #790550 02/22/07 06:27 AM
jdawg13 Offline OP
turned down the idle today and it hasn't surged yet!!
thank you very much that was driving me crazy!!!!
JAY
Re: 87 4Runna surging [Re: jdawg13] #790551 03/02/07 01:36 PM
sirus027 Offline
Have same problem. Will try lowering idle after work today.
For every tip on this board helping out a specific problem/person, there's probably another 10-20 or so with the same problem being helped out down the line. Thanks x2.
Re: 87 4Runna surging [Re: sirus027] #790552 03/02/07 08:15 PM
DRTDEVL Offline
No problem...
BTW: Did you know your 4Runner looks to have the same packages from the factory as Roger Brown's (aka 4Crawler)? He is a Toyota GOD, and can help you immensely with any issues.
Check his website for most issues surrounding the older 4Runners at http://www.4crawler.com/4Runner.shtml
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6291 MB (Peak: 0.7313 MB) Data Comp: Off Server Time: 2026-06-22 07:32:36 UTC
