Help! #790566 02/18/07 09:47 PM
G
goeco Offline OP
I sheared a lug stud today on my front driver side wheel.
Does anyone know where I can get a replacement stud and lug nut? Does anyone know if I can buy just one or will I have to get a complete set? Also, how hard to install? Any direction would be appreciated.
It is a 1996 T100 4wd
Thanks in advance,
Dave
Re: Help! [Re: goeco] #790567 02/18/07 10:05 PM
Jake97T Offline
Youll have to remove the hub to replace it, that is the hardest part, use a punch and a big hammer to drive out whats left of the broken one, you can usually get a single lug nut and stud at a tire shop.
Your hub comes off after you remove your lock outs or drive flanges, there is a bolt attached to your CV half shaft, then a 54mm lock nut, followed by another, hub slides off, unbolt your rotor, pound it out, hammer new one back on (need new front brakes? now is a good time to do it <img src="/forums/images/graemlins/smile.gif" alt="" />) put everything back on in order, it would probably cost $30 for somebody else to do this if your not comfortable with it.
Only specialty tool youll need is that 54mm hub socket or the equivalent standard size (2 1/16th i think)
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5884 MB (Peak: 0.6359 MB) Data Comp: Off Server Time: 2026-06-07 04:36:24 UTC
