Distributor bad? #790568 02/18/07 10:15 PM
DangerCart Offline OP
I pulled the the cap off and turned the engine over.The rotor was not moving. Now what else should I check?
1989 Dodge Raider 3.0L with 5-speed.
In limbo of what to do with it.
Re: Distributor bad? [Re: DangerCart] #790569 02/18/07 10:22 PM
CapnCrunch Offline
Might help to know more about what vehicle you have and type of engine.
If you happen to have a non-interference engine I suppose it could be that your timing belt is broken.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Distributor bad? [Re: DangerCart] #790570 02/18/07 10:22 PM
FrankR Offline
If you have a SOHC 3.0L V6, the timing belt is probably broken. To inspect, remove the black plastic cam sprocket cover that is located on the driver side (US models) engine front - just in front of the distributor.... held with 2 screws.
Frank
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5920 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-21 10:03:36 UTC
